3 Phasen Biber Blaumann
2001 Volkswagen Golf Free account, no CAN development support
18-11-2007, 17:18 Subject: How high should the starting amount be set? |
I have a VW Golf (AJM engine) with 287,000 km on the clock, and it's difficult to start when it's warm. I've tried all the usual things, but nothing helps!
The starting amount is 16.5 mg, and the corresponding value is 32768!
My question is: How much can I increase the initial amount? ehemals G4 ASZ, jetzt G4 ARL
Translated on 20-07-2026, 13:27.
Profile PM Garage |
18-11-2007, 17:35 Subject: Re: How high should the starting amount be set? |
3 Phasen Biber wrote: | | I have an AJM here... How far can I increase the starting amount? | Hi,
Depending on the software, you may be able to adjust certain settings, but the initial amount remains the same... at least that's how it seems to be with my Polo.
Just try it out, and after each change you make to the organ settings, briefly check the MWB 5 log; you should see the results there. Gruß Ulf
Translated on 20-07-2026, 13:28.
Profile PM Garage |
18-11-2007, 18:08 Subject: How high should the starting amount be set? |
I've now increased the amount to 17 mg through trial and error (value > 32786)!
The engine control unit (ECU) was installed without any problems, and the car now starts perfectly even when it's warm!
My question would have simply been, how far can I go up, if it wouldn't have achieved anything  . ehemals G4 ASZ, jetzt G4 ARL
Translated on 20-07-2026, 13:30.
Profile PM Garage |
Joined: 04/12/2002 Posts: 18142 Karma: +807 / -0 Location: St.Gallen 2018 Volkswagen T6
18-11-2007, 18:14 Subject: How high should the starting amount be set? |
Quote: | | My question would have simply been, how far can I go up, if it wouldn't have achieved anything |  .
Until it starts  .
Profile PM WWW Garage |
Rudi Guest
18-11-2007, 19:41 Subject: How high should the starting amount be set? |
My question would have simply been, how far could I go up, if it hadn't achieved anything  .
For many setpoint controllers (STGs) or channels, the minimum/maximum value is used when a value exceeds or falls below it.
Enter 40000 and see what happens.
Rudi
Translated on 20-07-2026, 13:31.
19-11-2007, 12:03 Subject: How high should the starting amount be set? |
@ Rainer
Okay, so if it hadn't worked at 30mg, would I have been able to increase the dose to 40mg? <= That was the question!
That is, of course, an exaggeration  . ehemals G4 ASZ, jetzt G4 ARL
Translated on 20-07-2026, 13:32.
Profile PM Garage |
