vwtommy
21-03-2008, 23:50 Subject: OBD for Mercedes Sprinter: Diagnostics & Repair |
"Hi, my father has a Mercedes-Benz Sprinter, model year 2001, 313CDI, and for some time now, the preheating indicator light has been coming on for a few minutes about 30 seconds after starting the engine. Also, the engine seems to have relatively low power since then. So, I thought I'd check it with OBD, but no luck. The connector for the KKL interface that I use for my Golf doesn't fit here, because Mercedes, of course, uses its own round connector, which is completely unnecessary. Well, it's not a huge deal to read the data just once, so I thought I could just clip it on with alligator clips. But on this car, every control unit has its own pin. I have the pinout information, also from OBD, but does anyone know if I need the K or the L wire?"
Thank you in advance for your help.
Best regards, Thomas.
Translated on 17-10-2026, 19:36.
Uwe@Ross-Tech Guest
22-03-2008, 18:27 Subject: OBD for Mercedes Sprinter: Diagnostics & Repair |
http://shop.dieselschrauber.de/images/obd2_diagnose_lt_sprinter.jpg
Please provide the text you would like me to translate from German to English. I will then provide the translation without any explanations.
http://shop.dieselschrauber.de/product_info.php/cPath/25/products_id/51/
-Uwe-
Translated on 17-10-2026, 19:38.
luiggi Schrauber
Joined: 02/19/2006 Posts: 392 Karma: +4 / -0 Location: Tirol /Zillertal
23-03-2008, 9:56 Subject: OBD for Mercedes Sprinter: Diagnostics & Repair |
If the preheating indicator light is illuminated or flashing, there is usually a problem with your glow plugs (one or more are defective), or with the preheating fuse/relay.
If there is an error in the engine control unit, the EDC warning light will illuminate.
Please check your spark plugs and the 80A fuse strip in the engine compartment.
chli1976 Profi-Schrauber
23-03-2008, 10:55 Subject: OBD for Mercedes Sprinter: Diagnostics & Repair |
I tried using this adapter with a Sprinter van manufactured in 1996, but it didn't work. Probably because that vehicle doesn't support OBD.
Translated on 17-10-2026, 19:39.
23-03-2008, 18:26 Subject: OBD for Mercedes Sprinter: Diagnostics & Repair |
chli1976 wrote: | | I tried using this adapter with a Sprinter from 1996, but it didn't work. | Probably because that vehicle doesn't yet support OBD. }
Is it expected... and is access possible via control unit address 01?
Profile PM WWW Garage |
23-03-2008, 21:06 Subject: OBD for Mercedes Sprinter: Diagnostics & Repair |
I tried using both 01 Motorelektronik and OBD II.
Translated on 17-10-2026, 19:40.
