MKB Codes: Find the Right Diagnosis Code
Go to page: 1, 2  Next
Michael II
Post31-12-2002, 10:21    Subject: MKB Codes: Find the Right Diagnosis Code Quote
I wanted to ask if there are any important MKB codes (error codes and target values) missing from the error database (ARL is already at the top of my list).
Tschüss
Michael II
Translated on 13-09-2026, 20:27.
Post31-12-2002, 10:28    Subject: MKB Codes: Find the Right Diagnosis Code Quote
Hi Michael,
"You listed automatic transmission as an option for the AXR. When will the automatic transmission be available? Currently, the D4 is only offered with a manual transmission."
Michael II
Post31-12-2002, 10:30    Subject: MKB Codes: Find the Right Diagnosis Code Quote
Hello Bertil,
Unfortunately, I don't know when or if that will be included in D4.
Tschüss
Michael II
Translated on 13-09-2026, 20:28.
Markus H.
Post31-12-2002, 15:56    Subject: MKB Codes: Find the Right Diagnosis Code Quote
@Michael II:
Thank you for including the AAT in the error database!
roter_Korsar
Post31-12-2002, 23:11    Subject: AEL: What is AEL? Explanation and Meaning Quote
Hey Michael II,
How about AEL?
Wishing you all the best for 2003 from Bielefeld.
Peter.
Translated on 13-09-2026, 20:29.
Post01-01-2003, 10:54    Subject: Login Codes: Generate & Verify Securely Quote
Hello Michael,
"Again, there have been repeated requests for login codes related to engine settings."
For example, with some PDs, you can probably access the menu using known logins, but changes to the settings are blocked icon_sad.gif.
I would suggest that, for the motors where not everything works correctly (with the code 12233), we should list the specific codes (potentially different for each channel) that apply to each motor.
Translated on 13-09-2026, 20:30.
Michael II
Post01-01-2003, 11:41    Subject: MKB Codes: Find the Right Diagnosis Code Quote
The login code 12233 is actually an undocumented function and is not considered in the standard documentation from VAG.
The adjustment being made primarily concerns the idle speed setting on certain engine control units (ECUs), where no login is required.
As mentioned before, this feature doesn't work with all ECUs. Unfortunately, I don't have information about whether there are other codes that might work. It's also possible that this function is simply not intended for certain ECUs for various reasons.
Tschüss
Michael II
Translated on 13-09-2026, 20:31.
brezelmann01
Karma: +75 / -0   Thank you, like it!
Post01-01-2003, 12:25    Subject: MKB Codes: Find the Right Diagnosis Code Quote
Hello Michael II!
Okay, I'm personally still interested in the 1.4 AMF, even though I suspect not many of you here have one. But still, if you could find something related to that, it would be great. I, at least, haven't found anything through my searches...
Your collection of error descriptions and solutions is truly excellent. I'd like to express a huge thank you on behalf of the entire forum! It's really fantastic, especially the documentation you've added in the last few days.
Take care.
pretzelman01
Translated on 13-09-2026, 20:32.
plexi32
Post01-01-2003, 12:55    Subject: MKB Codes: Find the Right Diagnosis Code Quote
Hello Michael,
ASZ is not included either. It would be great if there were some values available for that.
plexi32
Translated on 13-09-2026, 20:33.
Michael II
Post01-01-2003, 13:03    Subject: MKB Codes: Find the Right Diagnosis Code Quote
ASZ is already included.
Tschüss
Michael II
plexi32
Post01-01-2003, 13:23    Subject: MKB Codes: Find the Right Diagnosis Code Quote
Sure, here's the translation:
'super thx' translates to 'super thanks' or 'really thanks.' It's a casual and informal way of expressing gratitude.
Post01-01-2003, 14:12    Subject: MKB Codes: Find the Right Diagnosis Code Quote
Michael II wrote:
The login 12233 is actually an undocumented function and is not considered in the standard documentation from VAG.
As mentioned before, this doesn't work with all engine control units (ECUs). Unfortunately, I don't know if there are other codes available.
It is, of course, also possible that for some ECUs, this function is not intended for some reason.
Hi Michael,
That would mean that, for example, adjusting the injection start timing, the EGR rate, or shifting the stored pump characteristic curve (to fix minor jerking issues), or correcting the starting fuel quantity are not official workshop procedures icon_eek.gif icon_question.gif icon_question.gif.
While these options could, in my opinion, be used to address not only issues like jerky movements and starting problems, but also to mitigate "critical" exhaust emissions?
Well, that kind of makes sense, in a way.
"Replacing old, broken parts" instead of trying to bring them back into normal operating ranges through software is more attractive for workshops = it generates more revenue and requires less thinking icon_evil.gif.
Translated on 13-09-2026, 20:35.
Michael II
Post01-01-2003, 14:28    Subject: MKB Codes: Find the Right Diagnosis Code Quote
Hello Ulf,
I believe that VAG has good reasons for not making this an official tool. If you use these parameters, you should also be aware of the consequences. Especially since some of the effects are not immediately obvious (as is the case with an idle speed adaptation).
However, this would cause more problems for the existing installers than it would solve. The replacement option is not only more economically beneficial for the VAG group, but it also avoids fewer issues.
Tschüss
Michael II
Translated on 13-09-2026, 20:37.
Post01-01-2003, 14:35    Subject: MKB Codes: Find the Right Diagnosis Code Quote
Michael II wrote:
However, for the existing installers , this would cause more problems than it would solve. The replacement option is not only more economically viable for VAG, but it also causes fewer problems.
Hello Michael,
I have put the most important part of your answer in bold.
He's addressing a problem that most people here are probably already very familiar with.
I'm just wondering: if we, mostly amateurs, manage to use VAGCOM effectively in our free time, why does it seem impossible to train the professionals in the workshops so that "failures" are the exception, but not (as my personal impression is) the rule?
Translated on 13-09-2026, 20:38.
Michael II
Post01-01-2003, 14:53    Subject: MKB Codes: Find the Right Diagnosis Code Quote
Hello Ulf,
I think we're interested in finding a solution here, especially since these are our own cars. When it comes to our own vehicles, people are usually willing to think things through more carefully.
Tschüss
Michael II
Translated on 13-09-2026, 20:39.
Post01-01-2003, 20:23    Subject: MKB Codes: Find the Right Diagnosis Code Quote
Michael II wrote:
I think we are interested in finding a solution here, since these are our own cars.
People are often willing to think things through more deeply in such cases. icon_smile.gif
Hello Michael,
Nevertheless, it seems quite embarrassing for well-paid professionals when their highest corporate leadership = VAG, as your statements suggest, apparently (for good reason!) does not trust them to properly use digital tools in their own area of responsibility for troubleshooting, tools that are mastered by interested amateur autodidacts without causing damage icon_question.gif icon_exclaim.gif }.
Translated on 13-09-2026, 20:40.
No new posts Audi A4 B7/8E 1.8T BFB - Shaking/Vibration after cold start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Performance loss over time, MKB AFB, AKN, AKE, AYM Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A3, Differential Failure After Mileage Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Car pulls right after tire change Transmission, Chassis, Body & Interior
No new posts Increased fuel consumption after MFA following AGR decomm... Diesel Engine Technology
No new posts ASR Issue: Audi 8D/B5 Questions On-Board Diagnostics (OBD)
No new posts Non-TDI Questions: Everything You Need to Know Diesel Engine Technology
