Michael II Profi-Schrauber
Joined: 04/12/2002 Posts: 1132 Karma: +3 / -0 Location: Stuttgart
31-12-2002, 10:21 Subject: MKB Codes: Find the Right Diagnosis Code |
I wanted to ask if there are any important MKB codes (error codes and target values) missing from the error database (ARL is already at the top of my list).
Tschüss
Michael II
Translated on 13-09-2026, 20:27.
Bertil Profi-Schrauber
31-12-2002, 10:28 Subject: MKB Codes: Find the Right Diagnosis Code |
Hi Michael,
"You listed automatic transmission as an option for the AXR. When will the automatic transmission be available? Currently, the D4 is only offered with a manual transmission."
31-12-2002, 10:30 Subject: MKB Codes: Find the Right Diagnosis Code |
Hello Bertil,
Unfortunately, I don't know when or if that will be included in D4.
Tschüss
Michael II
Translated on 13-09-2026, 20:28.
Markus H. Guest
31-12-2002, 15:56 Subject: MKB Codes: Find the Right Diagnosis Code |
@Michael II:
Thank you for including the AAT in the error database!
roter_Korsar Guest
31-12-2002, 23:11 Subject: AEL: What is AEL? Explanation and Meaning |
Hey Michael II,
How about AEL?
Wishing you all the best for 2003 from Bielefeld.
Peter.
Translated on 13-09-2026, 20:29.
01-01-2003, 10:54 Subject: Login Codes: Generate & Verify Securely |
Hello Michael,
"Again, there have been repeated requests for login codes related to engine settings."
For example, with some PDs, you can probably access the menu using known logins, but changes to the settings are blocked  .
I would suggest that, for the motors where not everything works correctly (with the code 12233), we should list the specific codes (potentially different for each channel) that apply to each motor.
Translated on 13-09-2026, 20:30.
Profile PM Garage |
01-01-2003, 11:41 Subject: MKB Codes: Find the Right Diagnosis Code |
The login code 12233 is actually an undocumented function and is not considered in the standard documentation from VAG.
The adjustment being made primarily concerns the idle speed setting on certain engine control units (ECUs), where no login is required.
As mentioned before, this feature doesn't work with all ECUs. Unfortunately, I don't have information about whether there are other codes that might work. It's also possible that this function is simply not intended for certain ECUs for various reasons.
Tschüss
Michael II
Translated on 13-09-2026, 20:31.
brezelmann01 Profi-Schrauber
Joined: 09/14/2002 Posts: 714 Karma: +75 / -0 Location: Niedersachsen
01-01-2003, 12:25 Subject: MKB Codes: Find the Right Diagnosis Code |
Hello Michael II!
Okay, I'm personally still interested in the 1.4 AMF, even though I suspect not many of you here have one. But still, if you could find something related to that, it would be great. I, at least, haven't found anything through my searches...
Your collection of error descriptions and solutions is truly excellent. I'd like to express a huge thank you on behalf of the entire forum! It's really fantastic, especially the documentation you've added in the last few days.
Take care.
pretzelman01
Translated on 13-09-2026, 20:32.
plexi32 Guest
01-01-2003, 12:55 Subject: MKB Codes: Find the Right Diagnosis Code |
Hello Michael,
ASZ is not included either. It would be great if there were some values available for that.
plexi32
Translated on 13-09-2026, 20:33.
01-01-2003, 13:03 Subject: MKB Codes: Find the Right Diagnosis Code |
ASZ is already included.
Tschüss
Michael II
plexi32 Guest
01-01-2003, 13:23 Subject: MKB Codes: Find the Right Diagnosis Code |
Sure, here's the translation:
'super thx' translates to 'super thanks' or 'really thanks.' It's a casual and informal way of expressing gratitude.
01-01-2003, 14:12 Subject: MKB Codes: Find the Right Diagnosis Code |
Michael II wrote: | The login 12233 is actually an undocumented function and is not considered in the standard documentation from VAG.
As mentioned before, this doesn't work with all engine control units (ECUs). Unfortunately, I don't know if there are other codes available.
It is, of course, also possible that for some ECUs, this function is not intended for some reason. |
Hi Michael,
That would mean that, for example, adjusting the injection start timing, the EGR rate, or shifting the stored pump characteristic curve (to fix minor jerking issues), or correcting the starting fuel quantity are not official workshop procedures  .
While these options could, in my opinion, be used to address not only issues like jerky movements and starting problems, but also to mitigate "critical" exhaust emissions?
Well, that kind of makes sense, in a way.
"Replacing old, broken parts" instead of trying to bring them back into normal operating ranges through software is more attractive for workshops = it generates more revenue and requires less thinking  .
Translated on 13-09-2026, 20:35.
Profile PM Garage |
01-01-2003, 14:28 Subject: MKB Codes: Find the Right Diagnosis Code |
Hello Ulf,
I believe that VAG has good reasons for not making this an official tool. If you use these parameters, you should also be aware of the consequences. Especially since some of the effects are not immediately obvious (as is the case with an idle speed adaptation).
However, this would cause more problems for the existing installers than it would solve. The replacement option is not only more economically beneficial for the VAG group, but it also avoids fewer issues.
Tschüss
Michael II
Translated on 13-09-2026, 20:37.
01-01-2003, 14:35 Subject: MKB Codes: Find the Right Diagnosis Code |
Michael II wrote: | | However, for the existing installers , this would cause more problems than it would solve. The replacement option is not only more economically viable for VAG, but it also causes fewer problems. |
Hello Michael,
I have put the most important part of your answer in bold.
He's addressing a problem that most people here are probably already very familiar with.
I'm just wondering: if we, mostly amateurs, manage to use VAGCOM effectively in our free time, why does it seem impossible to train the professionals in the workshops so that "failures" are the exception, but not (as my personal impression is) the rule?
Translated on 13-09-2026, 20:38.
Profile PM Garage |
01-01-2003, 14:53 Subject: MKB Codes: Find the Right Diagnosis Code |
Hello Ulf,
I think we're interested in finding a solution here, especially since these are our own cars. When it comes to our own vehicles, people are usually willing to think things through more carefully.
Tschüss
Michael II
Translated on 13-09-2026, 20:39.
01-01-2003, 20:23 Subject: MKB Codes: Find the Right Diagnosis Code |
Michael II wrote: | | I think we are interested in finding a solution here, since these are our own cars. | People are often willing to think things through more deeply in such cases.
Hello Michael,
This effect is widely known.
Nevertheless, it seems quite embarrassing for well-paid professionals when their highest corporate leadership = VAG, as your statements suggest, apparently (for good reason!) does not trust them to properly use digital tools in their own area of responsibility for troubleshooting, tools that are mastered by interested amateur autodidacts without causing damage  }.
Translated on 13-09-2026, 20:40.
Profile PM Garage |
