Audi A3 Climatronic: Installation & Probleme
chriskross
Post28-06-2011, 14:25    Subject: Audi A3 Climatronic: Installation & Probleme Quote
Hello!
I'm having a problem with the air conditioner; it's not working, and the compressor isn't turning on.
The air conditioning system has been recharged.
under MWB 10.3, pressure switch/high-pressure sensor, F129, 0.0.
MWB10.2 Compressor intervention required. 1.0
MWB 10.1 0.0
I've already tried replacing the fan control unit for testing, but there's no change.
The pressure switch is also new.
There are 12V at the pressure switch.
I'm getting 2.8V on the signal cable of the pressure switch at the fan control unit.
The compressor shut-off conditions are also set to 0.
If I bypass the wires for the compressor coupling, the compressor runs.
Does anyone else have any ideas?
"Thank you."
A6 AFB
A6 BRE DPF
Translated on 06-09-2026, 23:54.
Post28-06-2011, 18:19    Subject: Audi A3 Climatronic: Installation & Probleme Quote
Please run a complete error scan.
There are only two possibilities.
- Climatronic is either not working or cannot be activated (due to a wiring fault).
- Climatronic not working (pressure switch signal).
Translated on 06-09-2026, 23:56.
chriskross
Post28-06-2011, 19:18    Subject: Audi A3 Climatronic: Installation & Probleme Quote
Hi!
Please find the scan attached.
Log-A3 HAL-235140km.txt
 File name:  Log-A3 HAL-235140km.txt
 File size:  4.2 KB
 Downloaded:  1686 times
A6 AFB
A6 BRE DPF
Post28-06-2011, 20:36    Subject: Audi A3 Climatronic: Installation & Probleme Quote
How about...
01039 - Sensor for coolant temperature indicator (G2).
30-10 - Interruption / Short circuit after positive voltage - Occasional.
00779 - Temperature sensor, outside temperature (G17)
30-00 - Interruption / Short circuit after positive
as a cause?
Translated on 06-09-2026, 23:57.
chriskross
Post28-06-2011, 20:45    Subject: Audi A3 Climatronic: Installation & Probleme Quote
I deleted it, and the errors have stopped appearing.
A6 AFB
A6 BRE DPF
Translated on 06-09-2026, 23:58.
Post28-06-2011, 21:02    Subject: Audi A3 Climatronic: Installation & Probleme Translating...
[Translating...]
RedR32
Avatar-RedR32
1998 Volkswagen Golf
Post28-06-2011, 22:29    Subject: Audi A3 Climatronic: Installation & Probleme Quote
chriskross wrote:
I deleted it
Without ulterior motives? Why are there errors in it?
reflexsilber met.
chriskross
Post29-06-2011, 6:35    Subject: Audi A3 Climatronic: Installation & Probleme Quote
Okay, I will check it again.
But if the G17/G89 sensors are providing incorrect values, then I should be seeing an "8" in the compressor shut-off conditions.
A6 AFB
A6 BRE DPF
Post29-06-2011, 8:35    Subject: Audi A3 Climatronic: Installation & Probleme Quote
What values do you have in measurement block 1, 10, and 11 of the Climatronic control unit, with the engine running and the "Auto" button previously pressed?
Translated on 06-09-2026, 23:59.
chriskross
Post29-06-2011, 9:18    Subject: Audi A3 Climatronic: Installation & Probleme Quote
Hello, the log file is attached.
Best,
Chris
 File size:  79.18 KB
 Viewed:  4800 times
A6 AFB
A6 BRE DPF
chriskross
dieselschrauber likes this.
Post29-06-2011, 10:46    Subject: Audi A3 Climatronic: Installation & Probleme Quote
The error was finally found; it was a burnt-out fuse that appeared to be okay upon measurement, but it had actually burned out over time. icon_mad.gif
"Thanks everyone."
 Sicherung A3 Climatronic
 File size:  384.5 KB
 Viewed:  1787 times
 File size:  348.7 KB
 Viewed:  1384 times
A6 AFB
A6 BRE DPF
Translated on 07-09-2026, 0:00.
Post29-06-2011, 11:55    Subject: Audi A3 Climatronic: Installation & Probleme Quote
The classic, as so often happens.
Thank you for your feedback.
Post29-06-2011, 15:05    Subject: Audi A3 Climatronic: Installation & Probleme Translating...
[Translating...]
No new posts Error code Climatronic 3B, model year 1999, 2000 model Troubleshooting & Guides
No new posts Climatronic Error: Doku Sharan 7M8 Fix Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Reading Faults - VW Climatronic from Hella Troubleshooting & Guides
No new posts T4 Climatronic: Climate Control System Transmission, Chassis, Body & Interior
No new posts Climatronic G3 TDI Transmission, Chassis, Body & Interior
No new posts Log Climatronic Upload
No new posts Climatronic Lighting: Installation & Troubleshooting Transmission, Chassis, Body & Interior
