Audi A6 C4: Crankshaft Pulley Bolts
OnkelTom
Post27-10-2026, 10:01    Subject: Audi A6 C4: Crankshaft Pulley Bolts Quote
Camshaft sprocket bolts for Audi A6 C4 2.5 TDI.
I need new screws for the camshaft pulleys to replace the timing belt.
These screws appear to be no longer available. Not even from Audi Tradition.
Where can I still find these screws (new)?
Camshaft sprocket, front.
Hexagon socket head screw (combination) N 901 439 06
M12 x 1.5 x 35, Grade 10.9
Rear camshaft sprocket.
Hexagon socket head screw (combination) N 904 721 01
M14 x 1.5 x 50
Translated on 27-10-2026, 10:03.
dieselschrauber likes this.
Post27-10-2026, 12:45    Subject: Audi A6 C4: Crankshaft Pulley Bolts Quote
schon mal beim Teiledienst nach dem Ersatz gefragt (neue Tl. Sure, here is the translation of the text from German to English:
"Nr.) ?"
It seems there is such a thing, for example, N 905 021 02.
Translated on 27-10-2026, 12:46.
Karma: +647 / -0   Thank you, like it!
Post30-10-2026, 8:14    Subject: Audi A6 C4: Crankshaft Pulley Bolts Quote
The engine is also used in the VW T4 and the Volvo 850... maybe try looking beyond the obvious or do a Google search.
Translated on 30-10-2026, 8:14.
Turbinchen
2014 Audi A4 Avant
Post31-10-2026, 20:50    Subject: Audi A6 C4: Crankshaft Pulley Bolts Quote
The latest part numbers for AAT/AEL are N90502103 for the front and N90472102 for the rear.
Translated on 31-10-2026, 20:51.
No new posts Audi A3 Steering Wheel Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake fluid change Audi A4 8K Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi Engine Codes: Types, MKB, GKB, AKB, MJ Technical Data
No new posts Differences in MSG for Audi 2.5 TDI AAT engines On-Board Diagnostics (OBD)
No new posts Tiptronic Problems Audi A4 B5 2.5 TDI Transmission, Chassis, Body & Interior
No new posts Audi 100 2.5 TDI: Adaptation Channels? On-Board Diagnostics (OBD)
No new posts Audi A4 B7: 2.5 TDI Issue Above 2500 RPM Diesel Engine Technology
