VW Polo 9N: No Longlife Oil Change Possible
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
Post05-05-2015, 12:08    Subject: VW Polo 9N: No Longlife Oil Change Possible Quote
On a Polo 9N manufactured in 2008, it is not possible to set the longlife service interval. In channel 45 of the instrument cluster, only the value "2" is available, not "4".
Does anyone have any ideas?
Address 01: Engine Control Unit (ECU) Label file: DRV\045-906-013-BMS.clb
Part number SW: 045 906 013 Part number HW: 045 906 013
Part: R3 1.4L EDC G000SG 9973
Revision: --H01--- Serial number: VWZ5Z0G5251250
Encoding: 0003071
Address 17: Control panel module
Label file: DRV\6Q0-920-xxx-17.lbl
Part number: 6Q0 920 825 F
Component: AGD V04 COMBINATION INSTRUMENT.
Encoding: 01132
Operating number: WSC 00000
Translated on 23-10-2026, 20:51.
Karma: +1354 / -0   Thank you, like it!
Post05-05-2015, 12:16    Subject: VW Polo 9N: No Longlife Oil Change Possible Quote
With access permission?
Edit: https://community.dieselschrauber.org/en/viewtopic.php?t=10656
Translated on 23-10-2026, 20:53.
DieselBär30x
Avatar-DieselBär30x
Post05-05-2015, 12:21    Subject: VW Polo 9N: No Longlife Oil Change Possible Quote
Hello everyone!
Another idea:
Populate the WSC with digits excluding zero?
Best regards from Munich!
Translated on 23-10-2026, 20:54.
lw-288
2007 Volkswagen Polo
Post05-05-2015, 13:37    Subject: VW Polo 9N: No Longlife Oil Change Possible Quote
@ Herbert
What does "with access permission" mean?
According to the tooltip, a "4" should be entered for channel 45, but it is being rejected with an error message.
Post05-05-2015, 14:07    Subject: VW Polo 9N: No Longlife Oil Change Possible Quote
For some adaptation channels, you can only make changes using an access code.
But first, check the link provided - according to the description there, for the Polo 9N, "2" indicates "longlife" oil.
Sure, here's the translation:
"Best regards," or "Sincerely,".
Translated on 23-10-2026, 20:55.
Post06-05-2015, 13:55    Subject: VW Polo 9N: No Longlife Oil Change Possible Quote
For the Golf 5 manufactured in August 2008, there was a known bug.
First, the AI models were completely replaced, then there was an event and an update.
As far as I know, he accepted the LL (likely referring to a warranty or service plan), but even after 15,000 km, it still started making noises indicating an oil problem.
I therefore had an X-KI installed in my Golf (where it was replaced).
Code:
Adresse 17: Schalttafeleinsatz        Labeldatei: RKS\1K0-920-xxx-17.lbl
   Teilenummer SW: 1K0 920 864 BX    HW: 1K0 920 864 BX
   Bauteil: KOMBIINSTRUMENT VDD 1212
   Revision: V0002000    Seriennummer: VWXBZ0G0722
   Codierung: 0007103
   Betriebsnr.: WSC 45489 142 62017
Translated on 23-10-2026, 20:56.
lw-288
Post19-05-2015, 12:09    Subject: VW Polo 9N: No Longlife Oil Change Possible Quote
It appears that the tooltip for the Polo 9N3 in VCDS is incorrect.
Channel 45 can only be tuned to channel 1 or 2.
No new posts VAG Longlife Oil Standards Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi Longlife Service: Your Best Choice Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Some information about the longlife service Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts After an oil change, does "Longlife" no longer apply? Diesel Engine Technology
No new posts VAG-COM: No Instrument Cluster Reading Possible On-Board Diagnostics (OBD)
No new posts Car won't start, headlights on? (Normal?) Transmission, Chassis, Body & Interior
No new posts Unable to save after update On-Board Diagnostics (OBD)
