poppel Blaumann
13-09-2015, 16:42 Subject: Unable to save after update |
Hello, after the update, I can see the status of the interface after the initial start and press the "Save" button, but the status is not being saved. I then have to go back to Settings - Connection Test - Save, and then start all over again. The status is not being saved even though everything is being recognized correctly. I have also tried uninstalling everything and completely re-downloading and reinstalling it. The same mistake, every time.
"Need Help."
Best regards, Thorsten.
Joined: 04/12/2002 Posts: 18135 Karma: +804 / -0 Location: St.Gallen 2018 Volkswagen T6
13-09-2015, 16:48 Subject: Unable to save after update |
Was the VCDS installation folder modified from the default location? It sounds like there might be missing or incorrect user permissions when saving.
Profile PM WWW Garage |
poppel Blaumann
13-09-2015, 19:28 Subject: Do not save |
Hello, no, the folder has not been modified. The user permissions are the same as always. There is only one user on the computer, and that user has administrator rights. Windows XP Professional.
I have now uninstalled and manually deleted all the folders. Then I restarted and reinstalled. The same problem persists. "Press Save" does not work. It is not being saved.
Thorsten.
13-09-2015, 19:45 Subject: Unable to save after update |
Diagnostic cable not connected to the car?
poppel Blaumann
13-09-2015, 20:53 Subject: Unable to save after update |
"You're right, the diagnostic cable isn't connected. Should it be plugged into the car?"
Thorsten.
13-09-2015, 21:43 Subject: Unable to save after update |
Yes, it's no longer possible without it.
I think it's been like that since the fourth-to-last version; before that, it always worked without the car.
Profile PM Garage |
poppel Blaumann
13-09-2015, 21:51 Subject: Unable to save after update |
Okay, I will test that tomorrow.
Thorsten.
