MrMcFly79 Blaumann
15-06-2022, 13:26 Subject: Audi A4 B7: Seat Occupancy Disable Coding |
Hello everyone,
I purchased S-Line seats for my A4. Unfortunately, the passenger seat does not have an occupancy sensor, which is why the airbag warning light is illuminated.
Is there a way to disable the detection feature?
Tobias.
Translated on 26-07-2026, 17:30.
Ich_Can_nix Profi-Schrauber
dieselschrauber likes this. |
15-06-2022, 16:19 Subject: Audi A4 B7: Seat Occupancy Disable Coding |
Hello Tobias,
Without knowing the exact part number (seat) and your vehicle's specifications (missing VIN) - I CANNOT provide a definitive answer.
For vehicle models, seat occupancy detection is not a component of the type approval process for vehicle registration and can therefore be coded. (Switch panel insert).
If the seat occupancy sensor is not working/malfunctioning, the seatbelt warning light should illuminate.
If the airbag light is on, it could be due to a problem with the side airbags.
If you set up a complete auto scan, we can more easily identify and resolve the problem.
Depending on your expectations for your work, there is also the possibility to retrofit an optimized seating arrangement. See TPI 2009748/8.
Part number: 8P4 963 553 B.
Michael.
Translated on 26-07-2026, 17:32.
MrMcFly79 Blaumann
19-06-2022, 9:29 Subject: Audi A4 B7: Seat Occupancy Disable Coding |
Hey Michael,
Thank you for your feedback. Please find the log attached. Unfortunately, it always crashes, but it shows that the error is related to the airbag.
Tobi.
| Description: |
 Download |
| File name: |
Log-11-WAUZZZ8E06A099548-1.txt |
| File size: |
3.5 KB |
| Downloaded: |
691 times |
Translated on 26-07-2026, 17:34.
19-06-2022, 16:37 Subject: Audi A4 B7: Seat Occupancy Disable Coding |
Hello Tobi,
The wiring is diagnostic-capable. You can either connect the seat occupancy sensor from the old seat or you must leave the installed test resistor in place.
Michael.
Translated on 26-07-2026, 17:35.
MrMcFly79 Blaumann
19-06-2022, 21:25 Subject: Audi A4 B7: Seat Occupancy Disable Coding |
Hi Michael,
That means the occupancy detection cannot be disabled?
Tobi.
MrMcFly79 Blaumann
21-06-2022, 10:36 Subject: Audi A4 B7: Seat Occupancy Disable Coding |
Ha, found it  .
Airbag -> Coding -> Enter "0" in the fourth position from the right...
Translated on 26-07-2026, 17:36.
Joined: 04/12/2002 Posts: 18138 Karma: +804 / -0 Location: St.Gallen 2018 Volkswagen T6
21-06-2022, 18:25 Subject: Audi A4 B7: Seat Occupancy Disable Coding |
Thank you for the feedback!
Profile PM WWW Garage |
