Schmierpfote Schrauber
Joined: 07/31/2016 Posts: 93 Karma: +21 / -0 Location: Erfurt
08-01-2017, 17:14 Subject: VW T6 Seatbelt Warning: Disable with VCDS |
Happy New Year to everyone. I received my T6 in January, and now my question: how can I disable the seat belt chime  ? Thank you for your help, Wolfgang.
Translated on 30-07-2026, 19:01.
Profile PM Email |
Joined: 04/12/2002 Posts: 18064 Karma: +797 / -0 Location: St.Gallen 2018 Volkswagen T6
08-01-2017, 17:19 Subject: VW T6 Seatbelt Warning: Disable with VCDS |
Please post the vehicle's Autoscan report!
Translated on 30-07-2026, 19:02.
Profile PM WWW Garage |
08-01-2017, 19:48 Subject: VW T6 Seatbelt Warning: Disable with VCDS |
Hello Rainer, here is the car scan. I hope I did everything correctly. Thank you, Wolfgang  .
| Description: |
 Download |
| File name: |
Log-WV2ZZZ7HZHH091255-730km.txt |
| File size: |
12.77 KB |
| Downloaded: |
1941 times |
Profile PM Email |
08-01-2017, 20:22 Subject: VW T6 Seatbelt Warning: Disable with VCDS |
Go to control unit address 17 (dashboard insert/combination instrument), then open the long coding assistant there and click through the bytes.
09-01-2017, 8:32 Subject: VW T6 Seatbelt Warning: Disable with VCDS |
Thank you very much, Rainer, for the quick help. Best regards, Wolfgang.
Translated on 30-07-2026, 19:03.
Profile PM Email |
09-01-2017, 19:27 Subject: VW T6 Seatbelt Warning: Disable with VCDS |
Hello everyone, how can I access the "Assi" function for long coding within address 17? Clicking on it doesn't work for me; am I doing something wrong? Thank you in advance for your answers.
- Wolfgang
Profile PM Email |
09-01-2017, 21:57 Subject: VW T6 Seatbelt Warning: Disable with VCDS |
Take a Screenshot.
Translated on 30-07-2026, 19:04.
09-01-2017, 23:00 Subject: VW T6 Seatbelt Warning: Disable with VCDS |
I took two pictures with my phone; I haven't taken a Screenshot yet. The first picture shows "Stg 17," and the second picture shows "07 Codierung."
| Description: |
| File size: |
3.91 MB |
| Viewed: |
1642 times |
| Description: |
| File size: |
1.47 MB |
| Viewed: |
1661 times |
| Description: |
| File size: |
2.97 MB |
| Viewed: |
4427 times |
Profile PM Email |
09-01-2017, 23:06 Subject: VW T6 Seatbelt Warning: Disable with VCDS |
Hello, it didn't work out very well. The first two images have a "07" code, while the third image has an "STG 17" long code. I still have a lot to learn. Thanks, Wolfgang.
Profile PM Email |
09-01-2017, 23:12 Subject: VW T6 Seatbelt Warning: Disable with VCDS |
Okay, and what happens when you click the "Coding Assistant" button?
Translated on 30-07-2026, 19:05.
09-01-2017, 23:35 Subject: VW T6 Seatbelt Warning: Disable with VCDS |
Sorry, I didn't dare to do that.  I have to drive through Thuringia again tomorrow. If I click on it, will it eventually display a "seatbelt warning" and remove the checkmark? Tomorrow after work, I will try it out. Thank you for your help, Wolfgang.
Profile PM Email |
10-01-2017, 0:34 Subject: VW T6 Seatbelt Warning: Disable with VCDS |
Schmierpfote wrote: | Sorry, I didn't dare to do that. I have to drive through Thuringia again tomorrow. If I click on it, will it eventually display a "seatbelt warning" and remove the checkmark? Tomorrow after work, I will try it out. Thank you for your help, Wolfgang. |
As long as you don't save the new encoding, nothing can go wrong with the encoding assistant.
Translated on 30-07-2026, 19:06.
10-01-2017, 0:41 Subject: VW T6 Seatbelt Warning: Disable with VCDS |
Thank you, Rainer. Do I need to enter numbers there, or just uncheck a box? I have no idea, but I'll figure it out eventually. Thank you very much, Wolfgang.
Translated on 30-07-2026, 19:07.
Profile PM Email |
10-01-2017, 11:54 Subject: VW T6 Seatbelt Warning: Disable with VCDS |
Schmierpfote wrote: | | Thank you, Rainer. Do I need to enter numbers there, or remove a corresponding checkmark? I have no idea, but I'm sure I'll figure it out eventually. Thank you very much, Wolfgang. |
Check or uncheck...
10-01-2017, 19:12 Subject: VW T6 Seatbelt Warning: Disable with VCDS |
Hello Rainer, everything worked out. VCDS and the help in the forum are simply great. Once again  Rainer, best regards, Wolfgang.
Translated on 30-07-2026, 19:08.
Profile PM Email |
10-01-2017, 21:10 Subject: VW T6 Seatbelt Warning: Disable with VCDS |
Great, thank you for the feedback! I would appreciate a Screenshot of the relevant byte in LCode.
