Torrn
13-02-2017, 12:45 Subject: Brake problem, ABS/ESP warning light on |
"Hello, in my Audi A4 B6, the brake warning symbol comes on while driving, accompanied by three beeps. Then the symbol either illuminates or flashes, and then it turns off again on its own!"
Error memory is empty.
Could it be that the ABS unit or control module is defective?
Translated on 18-07-2026, 4:40.
Joined: 04/12/2002 Posts: 18131 Karma: +804 / -0 Location: St.Gallen 2018 Volkswagen T6
13-02-2017, 12:53 Subject: Brake problem, ABS/ESP warning light on |
Please read the error memory immediately after it appears, and do not turn off the ignition while doing so!
When does the beeping occur â during diagnosis (which is normal), or during regular operation? Is the power connection to the vehicle's battery properly secured?
Translated on 18-07-2026, 4:41.
Profile PM WWW Garage |
Torrn
13-02-2017, 12:58 Subject: Brake problem, ABS/ESP warning light on |
dieselschrauber wrote: | Hi,
Best regards, Rainer |
The laptop was plugged in during the trip, then immediately checked, but it contained nothing.
The beeping occurs while driving.
What do you mean by "diagnosis (this is normal)" or "normal driving"?
"lg" translates to "best regards" or "kindly regards" in English. It is a common abbreviation used at the end of emails and letters.
Translated on 18-07-2026, 4:42.
13-02-2017, 13:04 Subject: Brake problem, ABS/ESP warning light on |
Wenn Du per Diagnose wÀhrend der Fahrt ins ABS/ESP gehst, piepst dieses herum, kann auch beim "Fehlerspeicher löschen alle SteuergerÀte" passieren. DaIt's normal.
Translated on 18-07-2026, 4:43.
Torrn
13-02-2017, 13:06 Subject: Brake problem, ABS/ESP warning light on |
dieselschrauber wrote: | Wenn Du per Diagnose wÀhrend der Fahrt ins ABS/ESP gehst, piepst dieses herum, kann auch beim "Fehlerspeicher löschen alle SteuergerÀte" passieren. DaIt's normal.
Okay, that makes sense!
As I mentioned, it happens while driving, and at various intervals; sometimes there's nothing for 10 minutes, then it starts happening constantly.
Translated on 18-07-2026, 4:44.
klahaui Profi-Schrauber
Joined: 08/13/2009 Posts: 1102 Karma: +125 / -0 Location: Vogtland, Land der Berge 2019 Volkswagen Golf Premium Support
13-02-2017, 20:46 Subject: Brake problem, ABS/ESP warning light on |
Check the brake fluid level and, if necessary, check the sensor for it.
Otherwise, the ABS control units often fail on the B6; I actually replaced one just last week.
Translated on 18-07-2026, 4:45.
Profile PM Garage |
13-02-2017, 21:42 Subject: Brake problem, ABS/ESP warning light on |
"...and do other control units also not have any errors? For example, communication errors with the ABS/ESP system. In that case, a vehicle scan would be helpful."
DieselBĂ€r30x Profi-Schrauber
Joined: 01/17/2008 Posts: 3560 Karma: +101 / -0 Location: MĂŒnchen & Passau
13-02-2017, 22:21 Subject: Brake problem, ABS/ESP warning light on |
Hello everyone!
Generally, there are two types of brake warnings to distinguish between:
1.) ABS-MIL (yellow) WITH brake system warning light (red).
2.) Only the brake warning indicator is illuminated (red).
**1.)**
Here's the error from the ABS control unit: The yellow ABS warning light indicates a partial or complete failure of the ABS system, while the additional brake system fault indicator with three audible warnings signals the resulting failure of the electronic braking force distribution (EBD) between the axles.
In this case, all the wheels receive the same braking pressure, which very quickly leads to the rear wheels locking up and consequently causing the rear of the vehicle to lose traction  .
However, there is always an error entry in the memory!
Regarding point 2:
As Klaui already mentioned, the brake fluid level is incorrect.
The ABS-MIL remains disabled, and all regulatory functions, including the Electronic Brake System (EBS), remain active.
No errors will be recorded in the AI or ABS Act.
Which of the two options is it exactly?
Best regards from Munich!
1. S.verlÀngerung: Audi A4 Avant quattro, 1,9 TDi MKB: AFN, BJ98, Vollausstattung, +VP1L
3. T5 1,9 TDI PD (AXC), BJ04 - nur Ărger!
Translated on 18-07-2026, 4:47.
13-02-2017, 23:27 Subject: Brake problem, ABS/ESP warning light on |
The warning message for low brake fluid level can usually only be reset to normal in VW/Audi vehicles by turning the ignition off.
If it disappears again like that, it's more likely a defective control unit (ECU) that intermittently stops functioning. In that case, as Rainer already mentioned, there should be communication errors in other ECUs.
Translated on 18-07-2026, 4:49.
Profile PM Garage |
RĂŒdi Profi-Schrauber
Joined: 03/05/2005 Posts: 1511 Karma: +645 / -0 Location: Nord/Osthessen 2001 Audi A4 Avant Premium Support
14-02-2017, 13:06 Subject: Brake problem, ABS/ESP warning light on |
Possibly the brake pads are worn down, or maybe the wear indicator is malfunctioning.
Translated on 18-07-2026, 4:50.
Profile PM Garage |
