VCDS: Check Compression Pressure
AutoserviceHenke
Post15-05-2017, 10:00    Subject: VCDS: Check Compression Pressure Quote
Hello everyone,
While browsing the extended measurement data and basic settings of a 2012 Passat, I came across the "Compression Test" section. I tried to start a dynamic compression pressure test, but it didn't display any results. This led me to wonder what these features are for and, if they work, how to perform a compression test.
Jens Henke.
Translated on 11-09-2026, 4:20.
No new posts Check TDI injectors with VCDS (Common Rail) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Battery Status with VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS: Resetting DSG Transmission Settings Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS: Check Timing for VW/Audi 3.0 TDI Engines Diesel Engine Technology
No new posts Check valve timing 2.0 CR with VCDS On-Board Diagnostics (OBD)
No new posts Low Compression: VW 2.5 TDI V6 AFB Engine Diesel Engine Technology
No new posts T4 Compression Pressure: How to Check & Fix Diesel Engine Technology
