LED Turn Signals & Taillights: Upgrade Guide
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
dennis91
Post17-07-2017, 19:33    Subject: LED Turn Signals & Taillights: Upgrade Guide Quote
Apparently, it's possible to convert the turn signals to LEDs because they can be recoded through the control unit.
Can someone explain how to code it using VCDS?
I would also like to disable the bulb monitoring for the reverse light.
How does the game work?
Translated on 20-08-2026, 23:22.
Post17-07-2017, 21:01    Subject: LED Turn Signals & Taillights: Upgrade Guide Quote
Which vehicle, Autoscan?
dennis91
Post18-07-2017, 17:52    Subject: LED Turn Signals & Taillights: Upgrade Guide Quote
dieselschrauber wrote:
Which vehicle,Autoscan?
Is this a Skoda Rapid Spaceback NH1 from the year 2016?
Translated on 20-08-2026, 23:23.
Post18-07-2017, 20:51    Subject: LED Turn Signals & Taillights: Upgrade Guide Quote
If you click on "Auto Scan," an explanation will also appear describing what it does.
dennis91
Post18-07-2017, 23:25    Subject: LED Turn Signals & Taillights: Upgrade Guide Quote
If you click on Autoscan, it will also explain what it is used for...
Okay, thank you icon_smile.gif. I'll upload the Autoscan here in a few days.
Translated on 20-08-2026, 23:24.
dennis91
Post23-07-2017, 14:14    Subject: LED Turn Signals & Taillights: Upgrade Guide Quote
Here is the desired Autoscan icon_smile.gif.
I hope this helps you.
Log-FO-DG 710-TMBEA6NH1H4513072-11445km.txt
 File name:  Log-FO-DG 710-TMBEA6NH1H4513072-11445km.txt
 File size:  10.15 KB
 Downloaded:  663 times
dennis91 likes this.
Post23-07-2017, 20:19    Subject: LED Turn Signals & Taillights: Upgrade Guide Quote
You can go through the individual bytes of the long coding sequence in the body control module (module address 09) and see if you can find anything related to the turn signals. Use the long coding assistant.
Translated on 20-08-2026, 23:25.
dennis91
Post24-07-2017, 13:30    Subject: LED Turn Signals & Taillights: Upgrade Guide Quote
Thank you! I'll take a look at it.
No new posts LED Rückleuchten Retrofit for Audi A6 4F Saloon Troubleshooting & Guides
No new posts Golf4: Turn signals flickering, wipers too slow, lights t... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A4 Bj7/96: Kurzschluß am Blinker-Relais ? Diesel Engine Technology
No new posts TD aus Typ 89/B3 umrüsten auf Quattro Diesel Engine Technology
No new posts UHV Low auf Premium umrüsten Electrical Systems, Vehicle Electronics, Multimedia
No new posts Blinker as Parking Light: Part No. 3C8 937 049 E On-Board Diagnostics (OBD)
