georgmech Schrauber
Joined: 09/10/2009 Posts: 69 Karma: +8 / -0 Location: Langenrohr
04-10-2016, 12:04 Subject: Audi A3 CRB: Hot News & Updates |
Hello, we have an AUDI A3 with a 2.0L engine (110kW CRB) that occasionally overheats, reaching 120 degrees Celsius before returning to normal. It then runs normally for a while before the problem repeats. The coolant thermostat has already been replaced.
Does anyone have any ideas?
Wir sind eine Werkstatt in Langenrohr bei Tulln und kämpfen täglich mit Fahrzeugproblemen. Wir sind sehr dankbar das es dieses Forum gibt , denn man kann nicht alles wissen, aber man kann sein Wissen weitergeben am Ende haben alle was davon
Translated on 26-07-2026, 20:32.
Profile PM Email |
Joined: 04/12/2002 Posts: 18135 Karma: +804 / -0 Location: St.Gallen 2018 Volkswagen T6
04-10-2016, 12:15 Subject: Audi A3 CRB: Hot News & Updates |
Hello Georg,
In some water pumps, it has happened that the impeller detached from the shaft. In such cases, the pump may spin freely, but very little or no water is actually being pumped.
Translated on 26-07-2026, 20:33.
Profile PM WWW Garage |
04-10-2016, 12:16 Subject: Audi A3 CRB: Hot News & Updates |
Water pump (with loose impeller) or cylinder head gasket.
Is there a certain pattern or system to it, so that you can, for example, trigger it by driving at full throttle on the highway?
Profile PM Garage |
georgmech Schrauber
05-10-2016, 11:34 Subject: Best German Shepherd Breeders: Find Yours Now! |
Thank you both. I'm ruling out a leak in the head gasket because there's absolutely no water consumption. However, a water pump could be the issue, but I find it hard to believe that we're still having the same problems as we did back in the 90s – have they really learned nothing? I'll replace the water pump next. Our mechanic actually has one in stock, so there must be a reason for that.
Translated on 26-07-2026, 20:34.
Profile PM Email |
georgmech Schrauber
dieselschrauber likes this. |
13-08-2018, 11:18 Subject: Water Wheel: History, Types & Working Principle |
Unfortunately, this is very late, but I'm not exactly an internet expert. The problem was with the water pump, specifically a sliding sleeve located above the impeller. This sleeve is controlled by a valve and water pressure, and it moves backward to open the circuit. However, this sliding sleeve got stuck.
Translated on 26-07-2026, 20:35.
Profile PM Email |
vag-driver Profi-Schrauber
13-08-2018, 13:00 Subject: Water Pump Wheel: Types & Applications |
georgmech wrote: | | This sliding sleeve is stuck. |
There are constructions where it is already clear what must come next  .
Andreas
Translated on 26-07-2026, 20:36.
