Basic adjustment, 7-speed DQ381 transmission
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
dennis91
Post18-02-2021, 16:22    Subject: Basic adjustment, 7-speed DQ381 transmission Quote
Hi there!
I wanted to use the instructions that Rainer provided us with (thank you for that!) to perform a basic adjustment of my DQ381 transmission.
However, the instructions only describe the procedure for transverse motors using older control units. What is the correct procedure when using newer control units?
You will find my car scan in the attachment.
Thank you!
Log-FO-DG 710-WVWZZZ3CZKE098588-20465km.txt
 File name:  Log-FO-DG 710-WVWZZZ3CZKE098588-20465km.txt
 File size:  26.54 KB
 Downloaded:  1054 times
Translated on 16-07-2026, 18:10.
Ich_Can_nix
Karma: +248 / -0   Thank you, like it!
dieselschrauber likes this.
Post18-02-2021, 18:08    Subject: Basic adjustment, 7-speed DQ381 transmission Quote
Hello and good day.
In your specific case, you should have it done professionally, unless you are a workshop or repair shop yourselves.
The vehicle was manufactured in April 2019 and is still covered by the manufacturer's warranty, with a documented extended warranty for an additional 3 years.
Many customers who own all-wheel drive vehicles complain about the gear changes.
There is a customer solution for the DQ381.
In some transmissions, the sliding bearings/shift levers for either the 6th gear or reverse gear have broken. Even a basic adjustment won't fix this issue.
You can of course delete the adaptation values/learning values and perform a basic calibration using the tester, but keep in mind that in the event of a warranty claim, the stored adaptation values may not match the mileage.
( The information comes from the man with ID DQ381 from Ingolstadt.)
This becomes relevant when Ingolstadt wants to access data from the transmission control unit for fault analysis. Currently, they are trying to determine why so many transmission failures are occurring.
Customer solution: Delete the adaptation values or have a software update installed to avoid any doubts in case of a warranty claim.
This may not answer your question directly, but it might help you make the right decision.
The customer solution is free of charge...
What are you complaining about? Why do you want to perform a basic reset?
Michael.
Translated on 16-07-2026, 18:13.
dennis91
Post18-02-2021, 18:20    Subject: Basic adjustment, 7-speed DQ381 transmission Quote
Hello Michael!
Thank you for the interesting contribution!
"In my opinion, the transmission seems to be grinding for too long."
"When the transmission is cold and you accelerate slowly, you can notice that the clutch engages very gradually (like when accelerating from 1st to 2nd gear), and then it suddenly grabs. This manifests as a slight, momentary jerk."
Greetings!
Dennis.
Translated on 16-07-2026, 18:15.
Karma: +796 / -0   Thank you, like it!
dennis91 likes this.
Post25-02-2021, 17:24    Subject: Basic adjustment, 7-speed DQ381 transmission Quote
Hello Dennis,
"has been updated regarding DQ381. If you're brave enough, please review and provide feedback on the measurement channels. Also, could you clarify what "IDE?????" refers to and how the specific points are named in the German version of VCDS."
Translated on 16-07-2026, 18:17.
dennis91
Post25-02-2021, 19:18    Subject: Basic adjustment, 7-speed DQ381 transmission Quote
Hello Rainer!
First of all, thank you for the update!
I would be willing to try it myself, but I wonder if Volkswagen knows what kind of device was used to reset the DSG transmission. If they do, then I'll probably have it done at the next service appointment.
But your entry is excellent; if someone has a car that's outside of its warranty period, they can definitely give it a try.
I will report if anything happens!
Translated on 16-07-2026, 18:18.
Post25-02-2021, 19:35    Subject: Basic adjustment, 7-speed DQ381 transmission Quote
See the post above.
@Ich_Can_nixViewing profile: Ich_Can_nix icon_cool.gif
Translated on 16-07-2026, 18:19.
No new posts VCDS: Resetting DSG Transmission Settings Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Throttle Body Initial Setup with VCDS (Gasoline Engine) Troubleshooting & Guides
No new posts 1.4 TSI CTHA basic settings not available in the engine c... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Grundeinstellung 7 Gang DSG 0AM On-Board Diagnostics (OBD)
No new posts Default setting for 6-speed DSG (DQ250) transmission Transmission, Chassis, Body & Interior
No new posts 7-Gang DSG Probleme nach Grundeinstellung On-Board Diagnostics (OBD)
No new posts Audi 4-Gang Automatic Transmission (097, CEB) Initial Setup On-Board Diagnostics (OBD)
