AGR Function: Questions and Answers
Juergen
Post01-06-2002, 15:16    Subject: AGR Function: Questions and Answers Quote
Hello!
If, purely hypothetically, one were to deactivate the AGR system as described in Ulf's article, should a control unit reset be performed to adapt the engine electronics to the changed conditions?
I once read that the engine control unit (ECU) can be reset to its default values by disconnecting the battery, and then it starts a new 'learning process.'
I would be very interested in that.
Best regards, Jürgen.
Translated on 02-08-2026, 10:07.
Post01-06-2002, 15:54    Subject: Engine Computer Reset: How To & Troubleshooting Quote
Hi.
Based on general experience, a reset is probably not necessary.
Furthermore, I doubt whether the TDI engine control unit (at least from the 1Z / AHU / AFN models) can actually be reset by disconnecting the battery: it doesn't have a constant power connection, and therefore wouldn't even register the disconnection. icon_wink.gif
You're probably confusing it with other engines.
Translated on 02-08-2026, 10:08.
Juergen
Post02-06-2002, 16:24    Subject: AGR Function: Questions and Answers Quote
Hi Ulf!
Thank you for the information!
Translated on 02-08-2026, 10:09.
No new posts Document A2 8Z0 MJ 2002, The radio displays "Transport" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts "Rain Shield" by No Touch: Practical Test General Tips
No new posts Resolution: "Crack in BKD cylinder head" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts PD Ignition Timing: How to Adjust It? On-Board Diagnostics (OBD)
No new posts "Service reminder function with VCDS" On-Board Diagnostics (OBD)
No new posts Motormanagement: Questions for Users Diesel Engine Technology
No new posts MyAutoscan: Function and Features Explained On-Board Diagnostics (OBD)
