Control Unit Not Recognized: Troubleshooting Guide
leonsberger
Post15-10-2003, 19:43    Subject: Control Unit Not Recognized: Troubleshooting Guide Quote
Hello everyone!
I'm having the following problem:
'I can no longer access the comfort control module using VAG-COM; it was working yesterday.'
Everyone else is reporting in without any issues.
Even with the AUTO-scan method, it cannot be found.
Does she have any idea?
I hope you can help me; I unfortunately couldn't find anything relevant using the search function.
Leonsberger.
Translated on 23-10-2026, 2:29.
WarLord
Post15-10-2003, 21:10    Subject: Control Unit Not Recognized: Troubleshooting Guide Quote
Hmm, I don't have a solution, but I have a question: What exactly is the 'Komfortsteuergerät' (comfort control unit), and from when was it installed?
Best regards, WarLord.
Translated on 23-10-2026, 2:30.
leonsberger
Post15-10-2003, 22:25    Subject: Control Unit Not Recognized: Troubleshooting Guide Quote
It is used to control the central locking system, alarm system, etc.
Can you configure settings like the honking sound when locking, the blinking frequency, the alarm tone, etc.?
Translated on 23-10-2026, 2:31.
Uwe@Ross-Tech
Post16-10-2003, 0:14    Subject: Control Unit Not Recognized: Troubleshooting Guide Quote
Golf 4, used or new?
Either a fuse is blown, or... Occasionally, the communication in these devices freezes. Since these devices are always powered (even when turned off), you have to reboot them. So, if all the fuses are okay, disconnect both cables from the battery, then hold the cables together for 10 seconds (this discharges the capacitors in the control units). Reconnect the cables.
-Uwe-
Translated on 23-10-2026, 2:32.
Gremlin
Post16-10-2003, 5:59    Subject: Control Unit Not Recognized: Troubleshooting Guide Quote
Yep, I can confirm that.
Sometimes, the komfort-STG system gets stuck during communication.
However, it is then sufficient to simply pull the relevant fuse (which will also turn off the interior lighting, serving as a kind of check).
CU Gremlin.
WarLord
Post16-10-2003, 10:11    Subject: Control Unit Not Recognized: Troubleshooting Guide Quote
Hmm, did the Passat 35i B4 already have something like that (I doubt it, though)?
Translated on 23-10-2026, 2:33.
leonsberger
Post16-10-2003, 17:45    Subject: Control Unit Not Recognized: Troubleshooting Guide Quote
'Thank you, the tip about the fuse worked. However, the control unit is not accepting the values I'm setting. I click 'Save' and confirm that it should write the values to the control unit, but the new value is not being applied.'
Do you have any other suggestions for me?
Gremlin
Post16-10-2003, 17:47    Subject: Control Unit Not Recognized: Troubleshooting Guide Quote
What exactly do you want to do?
CU Gremlin.
Translated on 23-10-2026, 2:34.
leonsberger
Post16-10-2003, 19:48    Subject: Control Unit Not Recognized: Troubleshooting Guide Quote
I would like to activate the horn to sound when locking the car and enable the interior monitoring feature of the alarm system. I have a Seat Leon TDI PD, model year 2002.
No new posts Reducer flow not detected Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Crafter: Second battery not charging Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS: HEX-USB CAN adapter not found after update General Tips
No new posts USB Interface not recognized On-Board Diagnostics (OBD)
No new posts Rear Door Problems: Sensor Not Detecting Opening On-Board Diagnostics (OBD)
No new posts Control Unit 46: Suddenly Unreachable? On-Board Diagnostics (OBD)
No new posts VP37 control unit no longer controls the pump On-Board Diagnostics (OBD)
