Document A3, Differential Failure After Mileage (Solution)
Michael II
Post29-08-2003, 9:26    Subject: Document A3, Differential Failure After Mileage Quote
Differential failure, even with gearbox housing damage as a consequential damage. Damage can only occur with high mileage (> 30000 km).
Cause
1. Insufficient fixation of the balancing gear axle.
2. Drilled hole for the balancing gear axle is not dimensionally accurate.
3. Offset cone wheels broken or eaten away.
4. Non-interference gear ring balancing housing disabled (only for 02K gearboxes).
All of these failure causes can result in a crack in the gearbox housing.
VAG Specification:
"If repairing the transmission is still worthwhile on vehicles outside the warranty, please also add to your complaint report which element of the differential, in your opinion, was the cause of the failure. "We should avoid generous concessions."
Tschüss
Michael II
Ratings - Document A3, Differential Failure After Mileage
No new posts Document: Performance loss over time, MKB AFB, AKN, AKE, AYM Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Golf 1J, from week 48/98, Clattering noise afte... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: A4, Emergency Procedure After Strong Acceleration Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts TDI ECU: Does it support mileage correction? On-Board Diagnostics (OBD)
No new posts Chip Tuning: Mileage Limits & Performance Diesel Engine Technology
No new posts Schleichender Leistungsverlust bei hoher Laufleistung HILFE! Diesel Engine Technology
This topic is locked, you cannot edit or reply. Can You Determine Engine Mileage? On-Board Diagnostics (OBD)
