dennis91
Joined: 07/01/2017 Posts: 50 Karma: +10 / -0 Location: Igensdorf
26-01-2020, 11:10 Subject: Default setting for 6-speed DSG (DQ250) transmission |
Hello everyone,
I wanted to reset the DSG (direct-shift gearbox) to its default setting on my VW Passat B8.
The problem isn't that everything is well described on the Ross-Tech website; it's something else.
Unfortunately, I can no longer access the measurement data blocks on the B8; I'm only able to get into the advanced settings, which isn't very helpful for me right now.
To perform the initial setup, I would need to go to the "Initial Setup" tab and then initiate each individual process.
Is there a guide for this from Ross-Tech?
I will add an Autoscan later this evening  .
Thank you very much in advance!
Translated on 18-07-2026, 19:41.
Joined: 04/12/2002 Posts: 18128 Karma: +803 / -0 Location: St.Gallen 2018 Volkswagen T6
26-01-2020, 12:13 Subject: Default setting for 6-speed DSG (DQ250) transmission |
Can you please post a Screenshot of what you see in the DSG control unit information?
Translated on 18-07-2026, 19:42.
Profile PM WWW Garage |
dennis91
26-01-2020, 20:07 Subject: Default setting for 6-speed DSG (DQ250) transmission |
dieselschrauber wrote: | Hello,
Best regards, Rainer |
Attached are some data; I hope this is what you were looking for  .
| Description: |
 Download |
| File name: |
DSG Grundeinstellungen.docx.pdf |
| File size: |
106.13 KB |
| Downloaded: |
2220 times |
| Description: |
 Download |
| File name: |
DSG Steuergeräteinfo.txt |
| File size: |
1018 Bytes |
| Downloaded: |
1101 times |
| Description: |
 Download |
| File name: |
Log-FO-DG710-WVWZZZ3CZHP012135-62925km.txt |
| File size: |
23.15 KB |
| Downloaded: |
1302 times |
Translated on 18-07-2026, 19:43.
27-01-2020, 18:54 Subject: Default setting for 6-speed DSG (DQ250) transmission |
I actually expected that the procedure for the basic settings in VCDS would be self-explanatory after selecting the dropdown menu as shown in your Screenshot, but I'm not sure.
I'll follow up and let you know.
Herbert Profi-Schrauber
27-01-2020, 21:03 Subject: Default setting for 6-speed DSG (DQ250) transmission |
Quote: | I wanted to bring the DSG transmission in my Passat B8 back to its default position.
At Ross-Tech, everything is described perfectly, so that's not the problem. |
Do you happen to have the link to the description?
Translated on 18-07-2026, 19:44.
dennis91
27-01-2020, 22:09 Subject: Default setting for 6-speed DSG (DQ250) transmission |
Herbert wrote: | Quote: | I wanted to bring the DSG transmission on my Passat B8 back to its default setting.
Herbert | .
http://wiki.ross-tech.com/wiki/index.php/6-Speed_Direct_Shift_Gearbox_(DSG/02E)
Yes, it's actually quite self-explanatory. However, even with the link mentioned above, there are a few things you need to be aware of. That's why I wanted to make sure I understood everything before proceeding.
Translated on 18-07-2026, 19:46.
dennis91 likes this. |
28-01-2020, 20:52 Subject: Default setting for 6-speed DSG (DQ250) transmission |
Hello.
"See below at:"
"Background information:"
https://forums.ross-tech.com/showthread.php?4090-MK7-GTI-and-R-DSG-Reset-of-Adaption-procedure
Feedback is welcome!
Translated on 18-07-2026, 19:48.
dennis91
dieselschrauber likes this. |
30-01-2020, 23:40 Subject: Default setting for 6-speed DSG (DQ250) transmission |
dieselschrauber wrote: | Hello.
"See below at:"
Okay, so I tried the basic setup today. Everything went well. There were no errors reported afterwards either. The subsequent test drive was also completed.
Thank you very much!
Translated on 18-07-2026, 19:49.
