Vehicle/model not supported
phil_g
Post17-12-2023, 18:44    Subject: Vehicle/model not supported Quote
Good day.
I've had a HEX-V2 for a few years now, which I acquired as part of a hardware upgrade. I haven't used the device much, but I wanted to get it working again because I recently acquired a new vehicle.
On my Windows 11 laptop, I have installed the latest version of VCDS (downloaded from the dieselschrauber shop).
When I run the connection test, it shows that everything is okay.
However, when I click on a control unit, I am shown a message indicating that the vehicle/model is not supported.
My vehicle is a VW T6.1 California MJ20232024.
What could be the reason for that?
Thank you in advance for your help.
Best regards.
philipp
 File size:  131.36 KB
 Viewed:  1460 times
 File size:  123.71 KB
 Viewed:  1322 times
Post17-12-2023, 19:11    Subject: Vehicle/model not supported Quote
Is VCDS blocked by some kind of firewall?
Post17-12-2023, 19:12    Subject: Vehicle/model not supported Quote
Please be patient. Ross-Tech can't be faster than the model's developers. X
If you want to help with vehicle support, a first step would be to perform a vehicle scan and post the results here.
PS: Your email forwarding through multiple hosts does not work with DMARC/DKIM, and therefore emails may not be delivered.
Post17-12-2023, 19:33    Subject: Vehicle/model not supported Quote
MJ 2023 refers to models manufactured from July 2022. VCDS 23.3 should theoretically already be able to handle that. A message from VCDS indicating that data for specific control modules is not available, I would have understood. Are other control modules accessible? A car scan would be important.
Is Windows 11 playing a trick here?
Does VCDS 23.11 from Ross-Tech work (downloadable from their website, and it's in English)?
phil_g
dieselschrauber likes this.
Post21-12-2023, 18:53    Subject: Vehicle/model not supported Quote
Hello everyone.
Thank you very much for your prompt replies.
The vehicle is approximately 1.5 months old. I don't know if any new control units or other components were installed.
I have attached the Autoscan report, which I just ran.
Thank you in advance for your support.
Best regards.
philipp
P.S.: @rainerViewing profile: rainer: Thanks for the tip regarding email forwarding.
Log-WV2ZZZ7HZRH022252_20231221_1844.txt
 File name:  Log-WV2ZZZ7HZRH022252_20231221_1844.txt
 File size:  17.78 KB
 Downloaded:  1999 times
Post21-12-2023, 21:03    Subject: Vehicle/model not supported Quote
"It's likely that the Lbl files are missing." Get the latest VCDS version from Ross-Tech.
Edit: Is the vehicle possibly MJ2024? MJ2023 and 1.5 months old are incompatible.
phil_g
Post22-12-2023, 9:00    Subject: Vehicle/model not supported Quote
Herbert wrote:
Edit: Is the vehicle possibly MJ2024? MJ2023 and 1.5 months old do not go together.
Hello Herbert.
It's quite possible that it's the MJ2024. I ordered it this year in August, and it was delivered to me in early November 2023.
Sorry for my imprecise statements.
Best regards.
philipp
Post22-12-2023, 9:37    Subject: Vehicle/model not supported Quote
It is definitely the 2024 model year, because...
- the model year begins in July of the previous year, so in this case, July 2023;
Post22-12-2023, 21:24    Subject: Vehicle/model not supported Quote
I forwarded the Autoscan data to Ross-Tech for further analysis.
Herbert likes this.
Post22-12-2023, 21:35    Subject: Vehicle/model not supported Quote
You can test the English version of VCDS 23.11 (link available in your customer account on the shop).
phil_g
dieselschrauber, Hutfahrer and Turbinchen likes this.
Post24-12-2023, 16:21    Subject: Vehicle/model not supported Quote
Hello everyone.
VCDS 23.11 was working.
At least the message that the vehicle/model is not supported no longer appears.
Thank you for your help and happy holidays!
philipp
werner_
Post13-11-2024, 12:02    Subject: Missing ??? file Quote
Good day.
I also have a vehicle that is not officially supported (Caddy MJ 2024). I had previously submitted a support request regarding this vehicle. However, unlike my previous request, I unfortunately received no response this time. Therefore, here's the car again.
Scan-WV2ZZZSK7SX025764-20241028-1553.txt
 File name:  Scan-WV2ZZZSK7SX025764-20241028-1553.txt
 File size:  6.39 KB
 Downloaded:  139 times
Post13-11-2024, 15:18    Subject: Re: Missing ??? file Quote
werner_ wrote:
Good day,
Best regards
Your software is neither ours nor is it up-to-date.
Sure, here's the translation:
"LG" translates to "Best regards" or "Sincerely" in English.
werner_
Post14-11-2024, 10:26    Subject: Program rewrite - similar result Quote
Good day.
My attempt today unfortunately also failed.
 File size:  439.67 KB
 Viewed:  264 times
Scan-WV2ZZZSK7SX025764-20241114-1001.txt
 File name:  Scan-WV2ZZZSK7SX025764-20241114-1001.txt
 File size:  7.18 KB
 Downloaded:  137 times
Post14-11-2024, 18:31    Subject: Vehicle/model not supported Quote
See the first part of.
No new posts VW Crafter: Second battery not charging Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS: HEX-USB CAN adapter not found after update General Tips
No new posts VAG VIN Decoder: Model, Year & Location Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS does not recognize Skoda Octavia; Gateway not supported On-Board Diagnostics (OBD)
No new posts TDI ECU: Does it support mileage correction? On-Board Diagnostics (OBD)
No new posts VW OBD Access: Car Not Accessible? On-Board Diagnostics (OBD)
No new posts VCDS AutoScan - Vehicle selection no longer working On-Board Diagnostics (OBD)
