Changing the transmission oil is advisable after >350,000 km
Go to page: 1, 2  Next
bindpe
Karma: +5 / -2   Thank you, like it!
Post26-02-2013, 21:35    Subject: Changing the transmission oil is advisable after >350,000 km Quote
Hello.
"Do you think it would be a good idea to change the transmission oil after 350,000 km? (Engine codes: AHU/GKB ASD). I haven't had any problems with the transmission except that it's a bit difficult to shift gears in cold temperatures."
I've often read on other forums that leaks have occurred after an oil change because the new oil is thinner. What are your experiences with this?
What do you think? Should I try to improve the transmission's performance and risk leaks, or should I just leave the old oil in?
THANK YOU.
Golf III TDI AHU 402Tkm
Spritmonitor.de
Translated on 21-07-2026, 17:49.
Post26-02-2013, 23:14    Subject: Changing the transmission oil is advisable after >350,000 km Quote
I would switch.
I doubt it's a leak. For that to happen, the old oil would have had to be very thick, and in that condition, proper functioning would likely have been severely compromised.
Translated on 21-07-2026, 17:50.
Post26-02-2013, 23:39    Subject: Changing the transmission oil is advisable after >350,000 km Quote
It is recommended to change it; in my case, it was changed at 220,000 km, and since then, the shifting has been easier, especially when cold. As of today, with 347,000 km, the transmission is still dust-dry icon_wink.gif. The old oil was noticeably darker than the fresh oil.
bindpe
Post27-02-2013, 1:26    Subject: Changing the transmission oil is advisable after >350,000 km Quote
Okay, I'll give it a try...apparently, the transmission appears to be dry on the outside.
Do you have any specific recommendations? Synthetic? Semi-synthetic?
"Besides the 17mm Allen key, are any other special tools required? Is there a sealing ring or similar component on the drain plug?"
Spritmonitor.de
Translated on 21-07-2026, 17:51.
Wiesel
Post27-02-2013, 10:39    Subject: Changing the transmission oil is advisable after >350,000 km Quote
If you don't have a 17mm Allen key, use a long nut with...
A 17mm wrench is a very inexpensive alternative.
The screw should have a conical thread – therefore, no sealing ring is needed.
Translated on 21-07-2026, 17:52.
Post27-02-2013, 10:58    Subject: Changing the transmission oil is advisable after >350,000 km Quote
And remember this tip: first remove the fill screw, then remove the outlet screw.
Translated on 21-07-2026, 17:53.
Post27-02-2013, 12:19    Subject: Changing the transmission oil is advisable after >350,000 km Quote
Wiesel wrote:
If you don't have a size 17 Allen wrench, use a long nut with...
The screw should have a conical thread - so no sealing ring is needed.
Weld two old wheel nuts together with the threads facing each other icon_smile.gif.
Post27-02-2013, 15:14    Subject: Changing the transmission oil is advisable after >350,000 km Quote
It can also be done with a suitable or appropriately filed pipe wrench. A size of 13x14 or 14x15 should work. icon_wink.gif
Translated on 21-07-2026, 17:54.
Wiesel
Post27-02-2013, 15:23    Subject: Changing the transmission oil is advisable after >350,000 km Quote
It's always a question of the effort involved icon_cool.gif.
The hardware store is right next door to me, and the price in this case was €0.
Welding/filing would have taken longer.
Translated on 21-07-2026, 17:55.
cumminsracer
Post27-02-2013, 17:15    Subject: Changing the transmission oil is advisable after >350,000 km Quote
Definitely make it simple! New oil never hurts, and the shifting behavior (operating forces, synchronization) often improves significantly shortly thereafter.
I've only had good experiences with Castrol fully synthetic oils, so I would recommend those.
I haven't usually been able to reach the specified fill amounts, so it's probably sufficient to buy, for example, two 1-liter bottles if the required amount is 2.1 liters. In a real pinch, you can always add a little bit from your "good old" supply.
Translated on 21-07-2026, 17:56.
bindpe
Post27-02-2013, 18:56    Subject: Changing the transmission oil is advisable after >350,000 km Quote
Hello.
According to Volkswagen, the part number G 060 726 A2 is the correct one for my transmission.
Costs approximately 8 euros per liter. Which manufacturer is behind it?
Thank you.
Spritmonitor.de
Translated on 21-07-2026, 17:57.
Post27-02-2013, 19:36    Subject: Changing the transmission oil is advisable after >350,000 km Quote
bindpe wrote:
Hello.
Thank you
Um NÖ.
I think it should be G 052726A2.
We have "converted" a T4 from 1991, needing a G 060726A2, to use Castrol TAF-X (and having a longer 5th gear), and it immediately shifted much better... and still does icon_wink.gif.
Translated on 21-07-2026, 17:58.
Post27-02-2013, 22:58    Subject: Changing the transmission oil is advisable after >350,000 km Quote
Now things are getting philosophical.
G 060 726 A2 appears to be the successor of G 052 726 A2, as indicated in the parts catalog for the ASD. However, both could potentially be SAE 75W.
Please check the specifications in your operating manual.
It is important that the oil is suitable for gearboxes and axles. For Castrol, I found the Syntrans Transaxle 75W-90, which meets VW specification 501.50 and API GL+. Shell offers the EP 75W-90 with the same properties.
Translated on 21-07-2026, 17:59.
mullemaus
Post27-02-2013, 23:12    Subject: Changing the transmission oil is advisable after >350,000 km Quote
Now it's getting philosophical.
G 060 726 A2 appears to be the successor of G 052 726 A2. The latter is listed in the parts catalog for the ASD. Both could, however, be SAE 75 W.
G 060 726 A2 = Usage numbers.
API GL-4
MB 235.10
SAE 75W
VW TL 521 71
VW TL 521 78
VW TL 525 12
VW TL 726-Y
General properties of manual transmission oil.
Color: yellow.
Contents: 1 liter.
Weight: 0.917 kg
Translated on 21-07-2026, 18:02.
klahaui
Avatar-klahaui
2019 Volkswagen Golf
Post28-02-2013, 19:40    Subject: Changing the transmission oil is advisable after >350,000 km Quote
Do all vehicles from the Volkswagen Group actually use 75W90 oil in their transmissions and differentials?
Translated on 21-07-2026, 18:03.
bindpe
Post28-02-2013, 21:19    Subject: Changing the transmission oil is advisable after >350,000 km Quote
I got myself the G 060 726 A2. Why? Because it already worked for the last 350,000 km icon_wink.gif.
I will report again after the change.
Spritmonitor.de
Translated on 21-07-2026, 18:04.
This topic is locked, you cannot edit or reply. Oil stain under the car - transmission fluid or brake fluid? General Tips
No new posts Document: Performance loss over time, MKB AFB, AKN, AKE, AYM Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A3, Differential Failure After Mileage Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Getriebeöl Diesel Engine Technology
No new posts Gear oil for VW Polo 6N2 Diesel Engine Technology
No new posts Change Transmission Fluid: DIY Guide & Tips Diesel Engine Technology
No new posts Audi C4 2.5 TDI - Transmission oil in coolant Diesel Engine Technology
