DSG 7-Speed: Problems After Reset
GTI
Post07-12-2014, 14:26    Subject: DSG 7-Speed: Problems After Reset Quote
Yesterday, I tried to perform the basic setup following the instructions.
The initial setup without the engine running didn't work (it was aborted for safety reasons). So, I then performed the procedure with the engine running. There was a rattling sound in the transmission, which is normal. Finally, the output message: "Process completed."
After that, I conducted the test drive as described.
Now, let's get to the problem:
When driving in mode D, the clutch disengages when I release the accelerator. The display then no longer shows D3/D4/D7, but only "D". When I brake, the gears re-engage and remain engaged.
At level "S", everything is normal.
Does anyone have an idea? I need to travel from Berlin to Chemnitz icon_sad.gif tomorrow.
The problem is that I can't check if the basic settings are complete because I don't have the main device. I only have a list where I can query thousands of data points by selecting them (e.g., measured values).
Tiguan Life Bj 2014 7-Gang DSG 2,0 TDI 4-Motion 177PS
Translated on 04-10-2026, 10:35.
Back to top Profile PM Email
Post07-12-2014, 14:50    Subject: DSG 7-Speed: Problems After Reset Quote
When driving in mode D, the clutch disengages when I take my foot off the accelerator.
What happens when you gently press the accelerator again and try to accelerate? Is there still a loss of power, or not?
Translated on 04-10-2026, 10:37.
GTI
Post07-12-2014, 14:56    Subject: DSG 7-Speed: Problems After Reset Quote
Then it immediately engages again, and numbers appear on the display.
Translated on 04-10-2026, 10:38.
Post07-12-2014, 16:03    Subject: DSG 7-Speed: Problems After Reset Quote
Isn't that the fuel-saving "sailing" feature, known from the Trabant 601?
GTI
Post07-12-2014, 17:35    Subject: DSG 7-Speed: Problems After Reset Quote
I would save a lot more money if the handle stayed in place...
Also, the Trabant didn't have an automatic transmission!
We just visited the Christmas market - however, there were no changes icon_evil.gif.
anywhere
Post07-12-2014, 17:38    Subject: DSG 7-Speed: Problems After Reset Quote
That sounds very much like the "free-running" function, so there should be something about that in the AI's settings (or it should be adjustable).
Translated on 04-10-2026, 10:39.
GTI
Post07-12-2014, 17:39    Subject: DSG 7-Speed: Problems After Reset Quote
Out of desperation, I also deleted all the learning values in the default settings a little while ago (hoping that it would accept new ones), but unfortunately, that didn't work either.
anywhere
GTI likes this.
Post07-12-2014, 17:56    Subject: DSG 7-Speed: Problems After Reset Quote
I believe the "free power" only comes when you are consuming power at the current rate.
I only had the Tiguan for one day - and that was quite some time ago. But actually, you should be happy right away icon_wink.gif.
Translated on 04-10-2026, 10:40.
GTI
Post07-12-2014, 18:00    Subject: DSG 7-Speed: Problems After Reset Quote
"That's it!" or "That's all!"
icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif Best Man icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif
What a stupid little checkmark! The question is how it was activated, or whether it's automatically enabled as a default setting...
Well, now everything is working again icon_razz.gif.
*happy*
Thank you very much new_all_coholic.gif new_all_coholic.gif new_all_coholic.gif new_all_coholic.gif.
Translated on 04-10-2026, 10:41.
No new posts VCDS: Resetting DSG Transmission Settings Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Throttle Body Initial Setup with VCDS (Gasoline Engine) Troubleshooting & Guides
No new posts 1.4 TSI CTHA basic settings not available in the engine c... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts DSG 0AM: Basic Adjustment for 7-Speed Gearbox On-Board Diagnostics (OBD)
No new posts Default setting for 6-speed DSG (DQ250) transmission Transmission, Chassis, Body & Interior
No new posts Basic adjustment, 7-speed DQ381 transmission Transmission, Chassis, Body & Interior
No new posts Audi 4-Gang Automatic Transmission (097, CEB) Initial Setup On-Board Diagnostics (OBD)
