DSG 0AM: Basic Adjustment for 7-Speed Gearbox
fazi
Post04-07-2013, 7:40    Subject: DSG 0AM: Basic Adjustment for 7-Speed Gearbox Quote
Good morning everyone.
After replacing the mechatronic unit on a 7-speed DSG transmission (model 0AM), we attempt to perform the basic adjustment.
Is there a guide available on how to do this with VCDS? I haven't been able to find anything.
Thank you for the answers.
Translated on 24-08-2026, 14:41.
Post04-07-2013, 10:08    Subject: DSG 0AM: Basic Adjustment for 7-Speed Gearbox Quote
Autoscan?
Please be careful with the default settings on the DSG (dual-clutch transmission). First, please provide vehicle data and information about the car and its DSG system.
fazi
Post04-07-2013, 10:32    Subject: DSG 0AM: Basic Adjustment for 7-Speed Gearbox Quote
Hello.
The old mechatronics system caused a short circuit. Therefore, the mechatronics system has been replaced. Now we are trying to perform the initial setup.
The Autoscan is included in the attachment.
Log-WVWZZZ1KZ8M288519-189950km.txt
 Autoscan
Autoscan
 File name:  Log-WVWZZZ1KZ8M288519-189950km.txt
 File size:  11.27 KB
 Downloaded:  1395 times
Translated on 24-08-2026, 14:42.
Post04-07-2013, 11:17    Subject: DSG 0AM: Basic Adjustment for 7-Speed Gearbox Quote
Thank you, please wait a moment.
Post04-07-2013, 20:49    Subject: DSG 0AM: Basic Adjustment for 7-Speed Gearbox Quote
Exercise caution when dealing with the DSG, as otherwise, a significant portion of it may be rendered unusable.
It's a good reason to carefully check the procedure beforehand and not click around hastily. icon_idea.gif
Translated on 24-08-2026, 14:43.
Post11-07-2013, 6:08    Subject: DSG 0AM: Basic Adjustment for 7-Speed Gearbox Quote
Here is an official guide:
http://wiki.ross-tech.com/wiki/index.php/7-Speed_Direct_Shift_Gearbox_%28DSG/0AM%29
See also:
Translated on 24-08-2026, 14:44.
No new posts VCDS: Resetting DSG Transmission Settings Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 1.4 TSI CTHA basic settings not available in the engine c... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Throttle Body Initial Setup with VCDS (Gasoline Engine) Troubleshooting & Guides
No new posts Default setting for 6-speed DSG (DQ250) transmission Transmission, Chassis, Body & Interior
No new posts Basic adjustment, 7-speed DQ381 transmission Transmission, Chassis, Body & Interior
No new posts DSG: No 6-Speed Default Setting Possible On-Board Diagnostics (OBD)
No new posts Audi 4-Gang Automatic Transmission (097, CEB) Initial Setup On-Board Diagnostics (OBD)
