Sharan II (7N): Gearbox Neutral Position
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
aietes
Post04-08-2017, 10:37    Subject: Sharan II (7N): Gearbox Neutral Position Quote
Hello everyone,
Unfortunately, I'm having a problem with my car and can't proceed. The target and actual values for gear recognition in my Sharan were different (at least the value when it was in neutral; the value only matched when I pushed the gear lever to the right).
A friend who has a workshop kindly lent me his VCDS device, and I found the adjustment/basic setting called "Transmission Neutral Position." Of course, I immediately started the process. When I press "Start" there, 2-3 texts appear in green very quickly one after another, and at the end it says "Finished." However, the values now only show 0.
I can't imagine being able to calibrate this sensor without somehow interacting with my gear stick. It must know which gear is engaged and when it's in neutral, right?
I have a 6-speed manual transmission!
Translated on 25-07-2026, 21:15.
Post04-08-2017, 10:55    Subject: Sharan II (7N): Gearbox Neutral Position Quote
Autoscan.
Translated on 25-07-2026, 21:16.
No new posts Doku Sharan 7M9, Engine Noises at MKB ANU Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts MKB ANU Engine Noises: Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Sharan 7M8, reduzierte Lenkunterstützung Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Gear Shift: Learn Neutral Position Calibration Transmission, Chassis, Body & Interior
No new posts Automatic Transmission AFN: Gearbox-Axle Assembly Oil Cha... Diesel Engine Technology
No new posts 5-Gang Getriebe auf 6-Gang Getriebe erweitern beim G3 AHU Diesel Engine Technology
No new posts Sharan 7N AGR Diesel Engine Technology
