Audi A4 B7: Seat Occupancy Disable Coding
MrMcFly79
Post15-06-2022, 13:26    Subject: Audi A4 B7: Seat Occupancy Disable Coding Quote
Hello everyone,
I purchased S-Line seats for my A4. Unfortunately, the passenger seat does not have an occupancy sensor, which is why the airbag warning light is illuminated.
Is there a way to disable the detection feature?
Tobias.
Translated on 26-07-2026, 17:30.
Ich_Can_nix
Karma: +253 / -0   Thank you, like it!
dieselschrauber likes this.
Post15-06-2022, 16:19    Subject: Audi A4 B7: Seat Occupancy Disable Coding Quote
Hello Tobias,
Without knowing the exact part number (seat) and your vehicle's specifications (missing VIN) - I CANNOT provide a definitive answer.
For vehicle models, seat occupancy detection is not a component of the type approval process for vehicle registration and can therefore be coded. (Switch panel insert).
If the seat occupancy sensor is not working/malfunctioning, the seatbelt warning light should illuminate.
If the airbag light is on, it could be due to a problem with the side airbags.
If you set up a complete auto scan, we can more easily identify and resolve the problem.
Depending on your expectations for your work, there is also the possibility to retrofit an optimized seating arrangement. See TPI 2009748/8.
Part number: 8P4 963 553 B.
Michael.
Translated on 26-07-2026, 17:32.
MrMcFly79
Post19-06-2022, 9:29    Subject: Audi A4 B7: Seat Occupancy Disable Coding Quote
Hey Michael,
Thank you for your feedback. Please find the log attached. Unfortunately, it always crashes, but it shows that the error is related to the airbag.
Tobi.
Log-11-WAUZZZ8E06A099548-1.txt
 File name:  Log-11-WAUZZZ8E06A099548-1.txt
 File size:  3.5 KB
 Downloaded:  691 times
Translated on 26-07-2026, 17:34.
Ich_Can_nix
Post19-06-2022, 16:37    Subject: Audi A4 B7: Seat Occupancy Disable Coding Quote
Hello Tobi,
The wiring is diagnostic-capable. You can either connect the seat occupancy sensor from the old seat or you must leave the installed test resistor in place.
Michael.
Translated on 26-07-2026, 17:35.
MrMcFly79
Post19-06-2022, 21:25    Subject: Audi A4 B7: Seat Occupancy Disable Coding Quote
Hi Michael,
That means the occupancy detection cannot be disabled?
Tobi.
MrMcFly79
Post21-06-2022, 10:36    Subject: Audi A4 B7: Seat Occupancy Disable Coding Quote
Ha, found it icon_smile.gif.
Airbag -> Coding -> Enter "0" in the fourth position from the right...
Translated on 26-07-2026, 17:36.
Post21-06-2022, 18:25    Subject: Audi A4 B7: Seat Occupancy Disable Coding Quote
Thank you for the feedback!
No new posts HEX-V2: Login failed Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS: Coding Daytime Running Lights - How To Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Seat Occupancy Detection VW Touran 2005 On-Board Diagnostics (OBD)
No new posts Fuel Injector Problem: 1Z Cylinder 4 GSK Removal? Diesel Engine Technology
No new posts Water Pump Replacement VW Sharan TDI (AC Removal?) Transmission, Chassis, Body & Interior
No new posts Broken Shock Absorber: Troubleshooting & Repair Transmission, Chassis, Body & Interior
