Brake Fluid Leak Caddy 2K - Rear Left
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Dieselschrauber Bar
3bAFN
Karma: +37 / -0   Thank you, like it!
Post04-10-2026, 12:44    Subject: Brake Fluid Leak Caddy 2K - Rear Left Quote
Hello.
I bought a Caddy 2K two years ago and have been working on it on and off ever since.
Now I was planning to go to the TÜV (German technical inspection), but the brakes on the left rear wheel aren't working at all. The brake caliper moves freely, and the handbrake mechanism is also working.
Fluid is present on all brake calipers except for the rear left one. I then worked my way through all the fittings, all the way to the ABS module, but nothing is leaking there either.
However, if I select the "bleed hydraulic unit" option in the basic settings via VCDS, brake fluid also reaches the rear left brake.
Since I've owned the car, only the right rear saddle has been replaced. Otherwise, no work has been done on the braking system.
It's a 2004 Caddy with the MK70 ABS system.
Do you suspect the problem is more likely related to the control unit or the hydraulic block?
Thank you very much for your ideas.
Sören.
Translated on 04-10-2026, 12:47.
Karma: +1361 / -0   Thank you, like it!
dieselschrauber likes this.
Post05-10-2026, 9:50    Subject: Brake Fluid Leak Caddy 2K - Rear Left Quote
How did you attempt to bleed the brakes? Did you apply pressure to the brake fluid reservoir, or did you use the brake pedal? Was the ignition on or off during the process?
It almost looks like the inlet valve for the brake on the rear left side of the ABS module is blocked. However, this should only happen when the system is activated.
Can you individually address the valves in the ABS module during an actuator diagnosis? If so, do they sound the same?
Don't forget to run the Autoscan!
Translated on 05-10-2026, 10:03.
Karma: +807 / -0   Thank you, like it!
Post05-10-2026, 15:23    Subject: Brake Fluid Leak Caddy 2K - Rear Left Quote
Please also check the brake hoses and the connection to the brake caliper for leaks, as brake fluid can leak out and air can get in, not always in both directions at the same time... icon_cool.gif
Aluminum O-rings, in particular, can sometimes look visually fine, even though they are partially corroded and damaged.
Translated on 05-10-2026, 15:24.
3bAFN
dieselschrauber, Herbert, Steffen G and Turbinchen likes this.
Post21-10-2026, 18:10    Subject: Brake Fluid Leak Caddy 2K - Rear Left Quote
The cause of the problem was a defect in the ABS module.
I was unable to get any brake fluid to the cylinder, whether with the ignition on or off. The pedal always felt like the system was free of air and closed.
I also couldn't make any progress with the actuator diagnostics. I couldn't find anything conclusive there.
ABS module replaced and everything is working fine.
Thank you.
Translated on 21-10-2026, 18:14.
Karma: +595 / -0   Thank you, like it!
Post22-10-2026, 18:00    Subject: Brake Fluid Leak Caddy 2K - Rear Left Quote
I've never experienced anything like that before.
Thank you for the report.
Translated on 22-10-2026, 18:00.
Karma: +649 / -0   Thank you, like it!
Post22-10-2026, 18:49    Subject: Brake Fluid Leak Caddy 2K - Rear Left Quote
"Something you might know from Ford."
Translated on 22-10-2026, 18:49.
3bAFN
Post23-10-2026, 10:20    Subject: Brake Fluid Leak Caddy 2K - Rear Left Quote
Rüdi wrote:
Known from Ford
Do you happen to know exactly what's defective in the ABS module?
Translated on 23-10-2026, 10:20.
This topic is locked, you cannot edit or reply. Oil stain under the car - transmission fluid or brake fluid? General Tips
No new posts Front Wheel Bearing Noise (Golf 4) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 5 Pulls to One Side: Diagnosis & Repair Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A3 8PA rear left brake dragging Transmission, Chassis, Body & Interior
No new posts Back door lock, Touran, left side, defective. Transmission, Chassis, Body & Interior
No new posts Audi A4 B8, rear left brake warm Transmission, Chassis, Body & Interior
No new posts Rear A6-4B Window: Automatic Open Issue? Diesel Engine Technology
