GRA Supplemental Restraint System (SRS) Installation Error Code 00588
Wiesel
Post25-08-2010, 21:45    Subject: GRA Supplemental Restraint System (SRS) Installation Error Code 00588 Quote
I installed the GRA lever in our Polo today.
So far, everything has worked as expected (GRA is functioning) - but now the airbag light is on icon_sad.gif.
Address 15: Airbag
Label file: RKS\6Q0-909-605-VW5.lbl
Part number: 1C0 909 605 K
Part number: 17 AIRBAG VW51 0N 0010
Encoding: 12599
Operating number: WSC 00788.
"One error found:"
00588 - Inflator for airbag (driver side) (N95)
33-00 - Resistance value too low.
I have.
- the battery disconnected.
- carefully detached the airbag.
- Unlocked and disconnected the connector to the slip ring using a small screwdriver.
- Airbag deployed.
- Steering wheel removed.
- Connector pulled from the steering column switch.
- Steering column switches and slip rings removed.
- Slip ring detached/disengaged.
- Slip ring clipped onto the new steering column switch.
- Cables laid.
- Steering column switches and slip ring installed.
- Reconnected the connector on the steering column switch.
- Steering wheel installed.
- Airbag cable connected to the slip ring.
- Airbag clipped in.
Does anyone have any idea what went wrong (or what I might have forgotten)?
Micha
Translated on 19-07-2026, 17:53.
Post25-08-2010, 21:49    Subject: GRA Supplemental Restraint System (SRS) Installation Error Code 00588 Quote
Certainly, the resistance is too low, which means there's likely a short circuit somewhere between the two cables. icon_exclaim.gif
Translated on 19-07-2026, 17:56.
Wiesel
Post25-08-2010, 22:21    Subject: GRA Supplemental Restraint System (SRS) Installation Error Code 00588 Quote
Okay, let's remove the airbag and see how the error "develops" or "progresses."
Eventually, there would have to be a point where the resistance becomes too great, or an interruption occurs.
Post25-08-2010, 22:26    Subject: GRA Supplemental Restraint System (SRS) Installation Error Code 00588 Quote
Wiesel wrote:
So, airbag out and let's see how the error "develops"...
At some point, there would inevitably be a "resistance too great" or an interruption
That's also my suggestion. There is no interruption for the ECU; there are only options for resistance that is too low, too high, or okay. icon_wink.gif
"Make sure the plug isn't just slightly misaligned, preventing the short-circuit bridge from being fully engaged while still making contact. Otherwise, there's usually nothing else that could cause this."
Translated on 19-07-2026, 17:57.
Wiesel
Post25-08-2010, 22:51    Subject: GRA Supplemental Restraint System (SRS) Installation Error Code 00588 Quote
TDI-GTI-4-Motion wrote:
There is no interruption for the TCU; there's only resistance that is too low, too high, or OK. icon_wink.gif
Does it then fit to the measurement block sections icon_confused.gif?
Maybe a connector isn't properly connected, so that the short circuit bridge hasn't been pushed away yet, but there's already contact. Nothing else can normally be the cause after something like that.
Arrrgh icon_evil.gif Sh... Short circuits.
"There's probably something similar lurking inside the connector of the steering column switch."
Translated on 19-07-2026, 17:59.
Post25-08-2010, 22:57    Subject: GRA Supplemental Restraint System (SRS) Installation Error Code 00588 Quote
Wiesel wrote:
Probably, there's something similar lurking inside the connector of the steering column switch as well.
They are located in each connector from the control unit to the igniter.
Translated on 19-07-2026, 18:00.
Wiesel
Post25-08-2010, 23:06    Subject: GRA Supplemental Restraint System (SRS) Installation Error Code 00588 Quote
You are right icon_wink.gif.
This is very nicely described in the secondary literature (e.g., 152).
Translated on 19-07-2026, 18:01.
Wiesel
Post26-08-2010, 18:04    Subject: GRA Supplemental Restraint System (SRS) Installation Error Code 00588 Quote
Okay, so the connector on the steering column switch could be pushed in another half a millimeter.
However, the light will only turn off again once the error in the control unit has been cleared.
Micha
Post26-08-2010, 18:10    Subject: GRA Supplemental Restraint System (SRS) Installation Error Code 00588 Quote
Wiesel wrote:
However, the lamp will only turn off again once the error in the control unit has been cleared.
Translated on 19-07-2026, 18:02.
Wiesel
Post26-08-2010, 18:55    Subject: GRA Supplemental Restraint System (SRS) Installation Error Code 00588 Quote
Wiesel wrote:
However, the lamp will only turn off again once the error in the control unit (STG) has been cleared.
Okay, I understand. Just for the sake of completeness, in case someone finds it through a search engine or Google.
Threat found.
Micha
Translated on 19-07-2026, 18:03.
Mc_Givertechnik
2010 Volkswagen T5
dieselschrauber likes this.
Post06-10-2010, 9:25    Subject: GRA Supplemental Restraint System (SRS) Installation Error Code 00588 Quote
If I may, I would like to add something.
I once encountered a similar error in a T4 vehicle, but in that case, it was due to a small coil breaking inside the connector for the airbag module. It appears there is some electronic circuitry within the small yellow airbag connector.
In this case, the error could only be fixed by replacing the coil spring, which is an expensive repair.
Peter.
VW T5 GP Multivan Startline CAAC 2,0 CRD 103 KW, Audi A2 1,4 16V AUA 2001, Audi A2 1,4 16V AUA 2003;Renault Zoe PHII 135 2020;
Translated on 19-07-2026, 18:04.
No new posts Doku A3 8L, Fehler 65535 im Airbag STG Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku A3 8L, Fehler 65535 im Airbag STG, bis 8LYA078299 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error Zünder 1 for Airbag (Passenger Side) - N131 Resistor Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Airbag error code 00588 Electrical Systems, Vehicle Electronics, Multimedia
No new posts Nach Update Fehler p1640 On-Board Diagnostics (OBD)
No new posts MSW 1Z: Many errors after cleaning On-Board Diagnostics (OBD)
No new posts Airbag Fehler On-Board Diagnostics (OBD)
