Default setting for 6-speed DSG (DQ250) transmission
dennis91
Post26-01-2020, 12:10    Subject: Default setting for 6-speed DSG (DQ250) transmission Quote
Hello everyone,
I wanted to reset the DSG (direct-shift gearbox) to its default setting on my VW Passat B8.
The problem isn't that everything is well described on the Ross-Tech website; it's something else.
Unfortunately, I can no longer access the measurement data blocks on the B8; I'm only able to get into the advanced settings, which isn't very helpful for me right now.
To perform the initial setup, I would need to go to the "Initial Setup" tab and then initiate each individual process.
Is there a guide for this from Ross-Tech?
I will add an Autoscan later this evening icon_smile_thumb_up.gif.
Translated on 18-07-2026, 20:41.
Post26-01-2020, 13:13    Subject: Default setting for 6-speed DSG (DQ250) transmission Quote
Can you please post a Screenshot of what you see in the DSG control unit information?
Translated on 18-07-2026, 20:42.
dennis91
Post26-01-2020, 21:07    Subject: Default setting for 6-speed DSG (DQ250) transmission Quote
Best regards, Rainer
Attached are some data; I hope this is what you were looking for icon_biggrin.gif.
DSG Grundeinstellungen.docx.pdf
 File name:  DSG Grundeinstellungen.docx.pdf
 File size:  106.13 KB
 Downloaded:  2188 times
DSG Steuergeräteinfo.txt
 File name:  DSG Steuergeräteinfo.txt
 File size:  1018 Bytes
 Downloaded:  1081 times
Log-FO-DG710-WVWZZZ3CZHP012135-62925km.txt
 File name:  Log-FO-DG710-WVWZZZ3CZHP012135-62925km.txt
 File size:  23.15 KB
 Downloaded:  1266 times
Translated on 18-07-2026, 20:43.
Post27-01-2020, 19:54    Subject: Default setting for 6-speed DSG (DQ250) transmission Quote
I actually expected that the procedure for the basic settings in VCDS would be self-explanatory after selecting the dropdown menu as shown in your Screenshot, but I'm not sure.
I'll follow up and let you know.
Post27-01-2020, 22:03    Subject: Default setting for 6-speed DSG (DQ250) transmission Quote
I wanted to bring the DSG transmission in my Passat B8 back to its default position.
At Ross-Tech, everything is described perfectly, so that's not the problem.
Do you happen to have the link to the description?
Translated on 18-07-2026, 20:44.
dennis91
Post27-01-2020, 23:09    Subject: Default setting for 6-speed DSG (DQ250) transmission Quote
Herbert wrote:
I wanted to bring the DSG transmission on my Passat B8 back to its default setting.
http://wiki.ross-tech.com/wiki/index.php/6-Speed_Direct_Shift_Gearbox_(DSG/02E)
Yes, it's actually quite self-explanatory. However, even with the link mentioned above, there are a few things you need to be aware of. That's why I wanted to make sure I understood everything before proceeding.
Translated on 18-07-2026, 20:46.
dennis91 likes this.
Post28-01-2020, 21:52    Subject: Default setting for 6-speed DSG (DQ250) transmission Quote
Hello.
"See below at:"
"Background information:"
https://forums.ross-tech.com/showthread.php?4090-MK7-GTI-and-R-DSG-Reset-of-Adaption-procedure
Feedback is welcome!
Translated on 18-07-2026, 20:48.
dennis91
dieselschrauber likes this.
Post31-01-2020, 0:40    Subject: Default setting for 6-speed DSG (DQ250) transmission Quote
Hello.
"See below at:"
Okay, so I tried the basic setup today. Everything went well. There were no errors reported afterwards either. The subsequent test drive was also completed.
Thank you very much!
Translated on 18-07-2026, 20:49.
No new posts VCDS: Resetting DSG Transmission Settings Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Throttle Body Initial Setup with VCDS (Gasoline Engine) Troubleshooting & Guides
No new posts 1.4 TSI CTHA basic settings not available in the engine c... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts DSG 0AM: Basic Adjustment for 7-Speed Gearbox On-Board Diagnostics (OBD)
No new posts Basic adjustment, 7-speed DQ381 transmission Transmission, Chassis, Body & Interior
No new posts 7-Gang DSG Probleme nach Grundeinstellung On-Board Diagnostics (OBD)
No new posts Audi 4-Gang Automatic Transmission (097, CEB) Initial Setup On-Board Diagnostics (OBD)
